The big question
Old December 2nd 05, 08:12 AM posted to rec.aviation.owning
Default The big question
What I want to know is:
If I want to have an airshow at my hotel, do I need a 337 to fix the
plastic sign on my AOPA plane before or after I pay my taxes?
Prime
Old December 2nd 05, 02:30 PM posted to rec.aviation.owning
It depends if it's a high wing or low wing.
"Prime" wrote in message
Prime
Old December 2nd 05, 03:45 PM posted to rec.aviation.owning
Prime writes:
How big are the numbers on the 337?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old December 3rd 05, 09:22 PM posted to rec.aviation.owning
"David Lesher" wrote in message
Prime writes:
If you have to take your sign through an ADIZ, you can use electrical tape
to make the 337 numbers big enough.
Capt. Geoffrey Thorpe
The Sea Hawk At WowWay D0t Com
Old December 2nd 05, 05:31 PM posted to rec.aviation.owning
Yes.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old December 2nd 05, 05:45 PM posted to rec.aviation.owning
How do you log the time spent running around the room making engine
noises with the plastic plane in your hand?
-jav
Old December 2nd 05, 08:23 PM posted to rec.aviation.owning
"Javier Henderson" wrote in message
PIC if you're solo. SIC if not...
Old December 5th 05, 04:40 AM posted to rec.aviation.owning
Does that apply to LSA, multi-engine, complex, etc.? :-)
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old December 5th 05, 06:25 AM posted to rec.aviation.owning
"Jack Allison" wrote in message
It depends on what kind of plane you're playing with...
I don't play with toy planes and make airplane noises when others are
around. ;-)
Old December 2nd 05, 05:53 PM posted to rec.aviation.owning
("George Patterson" wrote)
Yes.
You needed to quote all thirty-seven words for your one word answer?
Montblack
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
