Well, I have been giving primary instruction to my son... Started him
ab initio in the Apache... He has reached the point where he can get it out, gas and preflight, start and run up, taxi and takeoff, navigate across downstate Michigan, around Detroit, Toledo, Cleveland , and back, do stalls, enter and fly the pattern, configure for landing, make the appropriate radio calls, and land... The understanding was that I would teach him every bad habit known to man and then turn him over to a lucky instructor... After an hour and a half of grinding around the pattern on Sunday I decided I had done just that... "I'll ask Wally if he has time to go out with you." His eyes got big.. "I'm not ready for an instructor." "Sure you are... I'm plumb out of bad habits to teach you."... He had no argument to counter that... Wally was sitting in the lounge mumbling about going for lunch when I said, "Hey, Wally you got the time to take Dennis out for a while?"... The lounge got silent, all eyes on Wally... Wally kinda hunched down in his chair... "Well, sure... Ummm, but none of the airplanes are out." "I'll help you get one out." OK... Well, none of them have been plugged in." "Mine is never plugged in and it runs." His shoulders sagged... Check and mate... So, we pushed the hangar doors open and pulled the Warrior out... I turned Dennis over to him and became scarce... Wally put him through a half hour airplane quiz out on an 18 degree ramp... Then they fired up and went... Later I saw them doing touch and goes... Finally they came back in... Dennis became scarce... "So, how'd it go?", I asked Wally... He shrugged, said it was good, that he needs to look to one side during the flare , and that he had a time slot open on Wednesday afternoon... On the way home I asked Dennis, "So, how'd it go?"... He shrugged... "Well . . . . . . It was different... The single engine feels a lot different from the Apache... We went out and did takeoff and departure stalls, accellerated stalls, slow stalls, and slow flight... Then we came back for landings... boy, there sure isn't much to do compared to the Apache... Wally is a lot different from you... I retard the throttle and pull carb heat, and he pushes it off." (I am a fanatic about carb heat anytime the throttle is retarded.) "Wally talks non stop and all you do is grunt and point." (I do?) "Wally, really rolls the airplane around and you are always telling me, "Not so steep... Standard rate turns. Watch the pitch" Wally keeps telling me to look out of the airplane and you are always grunting and pointing at the altimeter, the air speed, the manifold pressure, the prop.. Wally is a lot more fun to fly with!" And that was it... So he is kicked out of the nest and making his own way... Now I'm really nervous... denny - grunting and pointing |
Thanks for sharing your experiences with your son's flight training. It sounds like he's well on his way to becoming a certificated airman. On 5 Dec 2005 05:05:33 -0800, "Denny" wrote in .com:: Wally is a lot different from you... I retard the throttle and pull carb heat, and he pushes it off." (I am a fanatic about carb heat anytime the throttle is retarded.) Naturally, there some differences between operating an Apache and a PA28; the latter only requires carburetor heat if there is an indication of carb ice. Dennis needs to get a copy of the Warrior POH, and familiarize himself with the differences. What's Dennis doing about getting his written exam out of the way? He should be studying the Gleim books: http://www.gleim.com/aviation/products.php?cat=PP#Books if he's not already. I presume Dennis has a Student Pilot certificate and has been logging his Apache PIC time. How many hours does he have logged now? |
way... Now I'm really nervous... Great story, as always. How old is your boy, Denny? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Congrats Denny, he'll do fine.
Even through all that grunting and pointing, I can tell you're proud of him. I look forward to that day with my son. Jim "Denny" wrote in message oups.com... Well, I have been giving primary instruction to my son... Started him ab initio in the Apache... He has reached the point where he can get it out, gas and preflight, start and run up, taxi and takeoff, navigate across downstate Michigan, around Detroit, Toledo, Cleveland , and back, do stalls, enter and fly the pattern, configure for landing, make the appropriate radio calls, and land... The understanding was that I would teach him every bad habit known to man and then turn him over to a lucky instructor... After an hour and a half of grinding around the pattern on Sunday I decided I had done just that... "I'll ask Wally if he has time to go out with you." His eyes got big.. "I'm not ready for an instructor." "Sure you are... I'm plumb out of bad habits to teach you."... He had no argument to counter that... Wally was sitting in the lounge mumbling about going for lunch when I said, "Hey, Wally you got the time to take Dennis out for a while?"... The lounge got silent, all eyes on Wally... Wally kinda hunched down in his chair... "Well, sure... Ummm, but none of the airplanes are out." "I'll help you get one out." OK... Well, none of them have been plugged in." "Mine is never plugged in and it runs." His shoulders sagged... Check and mate... So, we pushed the hangar doors open and pulled the Warrior out... I turned Dennis over to him and became scarce... Wally put him through a half hour airplane quiz out on an 18 degree ramp... Then they fired up and went... Later I saw them doing touch and goes... Finally they came back in... Dennis became scarce... "So, how'd it go?", I asked Wally... He shrugged, said it was good, that he needs to look to one side during the flare , and that he had a time slot open on Wednesday afternoon... On the way home I asked Dennis, "So, how'd it go?"... He shrugged... "Well . . . . . . It was different... The single engine feels a lot different from the Apache... We went out and did takeoff and departure stalls, accellerated stalls, slow stalls, and slow flight... Then we came back for landings... boy, there sure isn't much to do compared to the Apache... Wally is a lot different from you... I retard the throttle and pull carb heat, and he pushes it off." (I am a fanatic about carb heat anytime the throttle is retarded.) "Wally talks non stop and all you do is grunt and point." (I do?) "Wally, really rolls the airplane around and you are always telling me, "Not so steep... Standard rate turns. Watch the pitch" Wally keeps telling me to look out of the airplane and you are always grunting and pointing at the altimeter, the air speed, the manifold pressure, the prop.. Wally is a lot more fun to fly with!" And that was it... So he is kicked out of the nest and making his own way... Now I'm really nervous... denny - grunting and pointing |
Yeah, that was his first time in a Warrior, and Wally just did a
preflight and ramp quiz and went.. I sprang it on Wally and he didn't have the time for the usual classroom spiel... I am sure he will have Dennis read the POH. I have a high school classmate that got real dead when he had carb ice in a Cherokee and then tried to stretch the glide... I have had carb ice in Cubs, T-Crafts, Aeroncas, Cherokees, SkyHawks, Skylanes, Apaches, and a bunch I don't remember right at the moment (al what's hiz names disease)... As far as I'm concerned the carb heat is on anytime the throttle comes back... Never saw a crash from using carb heat... So, Gleim is the one? Actually, he has a book and is half way through it... When he finishes then I will order the DVD with the certificate option, for him to do the second time around... He needs to get his ASEL, then we will send him for 'legal' instruction in the Apache... My intent was to get him to the point that he can handle the airplane reasonably well and then turn him over to a CFI, not for me to prepare him for the check ride... denny |
On 5 Dec 2005 08:57:00 -0800, "Denny" wrote in
om:: I have a high school classmate that got real dead when he had carb ice in a Cherokee and then tried to stretch the glide... I have had carb ice in Cubs, T-Crafts, Aeroncas, Cherokees, SkyHawks, Skylanes, Apaches, and a bunch I don't remember right at the moment (al what's hiz names disease)... As far as I'm concerned the carb heat is on anytime the throttle comes back... Never saw a crash from using carb heat... I understand. It can be difficult to detect incipient carb heat issues at low power near the ground in time to apply it. So, Gleim is the one? Wally may have other ideas, but I recommend Gleim for test preparation. Their red books present only the information covered on the tests, but with sufficient detail to assure complete understanding. I've no experience with their complete courses, but if the red books are any indication, they should be clearly written and logically present the information. He needs to get his ASEL, then we will send him for 'legal' instruction in the Apache... My intent was to get him to the point that he can handle the airplane reasonably well and then turn him over to a CFI, not for me to prepare him for the check ride... According to: http://ecfr.gpoaccess.gov/cgi/t/text... 1.1.2.1.1.30 § 61.51 Pilot logbooks it seems that Dennis would have had to be a (certificated?) student pilot to log the time you instructed him. I hadn't realized that. |
| Thread Tools | |
| Display Modes | |
