floatplane - taking off frozen lake
Old December 6th 05, 04:12 AM posted to rec.aviation.piloting
Default floatplane - taking off frozen lake
heres a video i figured some would enjoy
float plane taking off from a semi-frozen lake in alaska
http://media.putfile.com/Seaplane---...-Bethel-Alaska
Old December 6th 05, 05:21 AM posted to rec.aviation.piloting
"Lets Fly" wrote in message
Would puncturing a float be a concern when it comes to ice?
Jay Beckman
Old December 6th 05, 06:02 AM posted to rec.aviation.piloting
That guy had more nuts than brains.
Old December 6th 05, 06:50 AM posted to rec.aviation.piloting
A punctured float is always a concern, but slush isn't likely to puncture a
float; it just makes a ton of drag.
My buddy Buzz Fiorini used to fly his C180 floatplane over to Sun Valley and
land on a snow-packed meadow. Did it regularly, for years, with no damage.
May have put ski wax on his floats.
Seth
"Jay Beckman" wrote in message
newsd9lf.11192$Wu.3984@fed1read05...
Jay Beckman
Old December 6th 05, 08:03 AM posted to rec.aviation.piloting
Not if the ice is flat, solid, and strong enough to support the airplane.
However, broken ice floating just below the surface is a significant risk.
It certainly can tear the skin of a float or the hull of a boat-hull
seaplane, and if the conditions are right, the ice is completely invisible.
The video posted is crappy as all get out (not only is the source analog,
but it looks like the tape's been used a zillion times before). It's hard
to tell if the ice is solid or not...it seems as though the ice during the
backtaxi isn't. But the floats do seem to stay on top during the takeoff.
Seems to me that's probably a matter of luck than good planning though,
since the airplane was clearly not supported by the ice at the beginning of
the video.
Pete
Old December 6th 05, 10:43 AM posted to rec.aviation.piloting
Its not particuarly dangerous, but it isn't very good for the floats.
If you hit a chuck of ice at high speed it may dent the floats.
Possible to puncture. I would be suprised if this guy did not damage
his floats (a dent or two). But given a smooth surface, no ice chunks,
either hard ice or slush or even packed snow, it could be done,
obviously, by witness of the video.
Desperate men do desperate things.
On Mon, 5 Dec 2005 22:50:29 -0800, "Seth Masia"
During WWII in a whiteout, a PBY Catalina was flying over the
Greenland ice cap at 10,000-plus feet when the crew realized that
though the engines were developing full revs, the plane wasn't moving
any longer. They'd landed on the snow. They piled out and ran around,
laughing. Then they realized that, no, they weren't going to take off
again.
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old December 6th 05, 10:46 AM posted to rec.aviation.piloting
The Helio Aircraft Co. at Pittsburg, KS operated straight
float equipped Helio H-295 Couriers from the grass strip
behind the factory. They would land on dry grass but did
spray a little water on the grass in the area of the plane
to let it start to slide. The landing was tricky only
because there was not suspension.
The Helio was unusual and could fly at gross (3,400 pounds)
at 28 mph.
"Cub Driver" usenet AT danford DOT net wrote in message
realized that
wasn't moving
ran around,
to take off
| again.
Old December 6th 05, 12:30 PM posted to rec.aviation.piloting
Dan,
Actually the airplane that came to a stop in the whiteout over
Greenland was a B-17 (My Gal Sal). That began a very long rescue
effort (some months) in which a number of people died getting the crew
out.
What you may be recalling is that the legendary Bernt Balchen (first
person to pilot an aircraft over both poles, Byrd's pilot across the
Atlantic in 1927 and over the South Pole in 1929) landed a PBY, gear
up, on the ice pack a number of times during the rescue (he also
successfully took off). He also landed on a temporary lake that formed
on the ice pack due to melting ice.
All the best,
Rick
again.
Old December 6th 05, 01:21 PM posted to rec.aviation.piloting
It wasn't the ice, but the TREES that I was commenting at, he almost
ate it. :)
Lake effect snow Paul Tomblin Instrument Flight Rules 7 November 23rd 05 08:00 PM
(Very Long) Canadian fishing adventure JJS Piloting 6 July 5th 05 12:13 PM
The National Lake Eutrophication Survey 1971-1973 Badwater Bill Home Built 18 June 16th 04 02:27 AM
Great Lakes lake effect snow Paul Tomblin Instrument Flight Rules 30 October 21st 03 05:15 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
