I just bought the Hood Lamb and had to send them back. They simply would
not clamp to my David Clark H10-13.4 which have a narrower than usual band. To their credit, they acknowledge this problem with DC's and suggest friction tape to increase the girth of the band. Didn't work...to rinky-dink for me. I replaced them with the kind with a head band. Not sure they'll work with glasses, but I think they will. Rod "Snowbird" wrote in message om... OK, I'd like to tap into the ingenuity of the group here. We have Lightspeed headsets. We use Foggles for simulated instrument training. I don't like it, because the earpieces of the Foggles create a sound gap. I saw a cool product for IFR training which clipped onto the band of a headset with tiny little bands, and flipped up and down to limit one's view or move out of the way. It's called the Hood Lamb (for example: http://www.pilotshop-usa.com/store/i...PARTMENT_ID=78 Unfortunately, it only fits on headsets with steel bands, like DC's or Sigtronics. It looked like something a clever chap ought to be able to duplicate with a bit of ingenuity, given the requisite parts -- some kind of swivel, and some kind of clamp which would fit the wider plastic band of the Lightspeed headsets. There is a clever chap in our house. Can anyone suggest a source of little clamps and the like? (ie a widget catalog?) Thanks! Sydney |
Hi Sydney,
I've got Lightspeeds and although the noise was never a problem, the way they press the bows of the foggles into my brain starts to bother me after awhile. I've often thought about buying a cheap pair of wire frame sunglasses and cutting the bows off them, then also cutting most of the bows off the foggles, leaving the corner pieces of course. Then I thought of drilling several holes in the side pieces of the foggles and weaving the wire frame bows or attaching them to the foggles somehow. Just an idea that admittingly needs some work but it would make the space between the earcup and your head smaller. -- Jim Burns III Remove "nospam" to reply |
Snowbird wrote: We have Lightspeed headsets. We use Foggles for simulated instrument training. Jeppshades work with Lightspeed headsets and there's nothing to interrupt the ear seal. If you figure out a way to hook a hoodlamb to LS, let me know. I was inspired by the hoodlamb and made something similar out of a folded piece of cardboard and some rubber bands with home-made clips to attach to the headset. I used it for my private but it lacked the easy flip-up/flip-down you'd get with a real hoodlamb. -- Ben Jackson http://www.ben.com/ |
That looks like a cool device. Thanks for posting the pointer!
I've been dissatisfied with Foggles too, both because of the discomfort of putting the stems under the headset (I wear contacts instead of glasses, and use Shields sunglasses that have a string instead of stems, so only Foggles present this problem for me), and also because they don't really limit my outside vision adequately. I'd been meaning to try to find or devise some alternative, but so far this year I've been able to stay current just by shooting approaches in benign IFR, so I've kind of forgotten about the foggles. (Sorry, no idea about the widget catalog.) --Gary "Snowbird" wrote in message om... OK, I'd like to tap into the ingenuity of the group here. We have Lightspeed headsets. We use Foggles for simulated instrument training. I don't like it, because the earpieces of the Foggles create a sound gap. I saw a cool product for IFR training which clipped onto the band of a headset with tiny little bands, and flipped up and down to limit one's view or move out of the way. It's called the Hood Lamb (for example: http://www.pilotshop-usa.com/store/i...PARTMENT_ID=78 Unfortunately, it only fits on headsets with steel bands, like DC's or Sigtronics. It looked like something a clever chap ought to be able to duplicate with a bit of ingenuity, given the requisite parts -- some kind of swivel, and some kind of clamp which would fit the wider plastic band of the Lightspeed headsets. There is a clever chap in our house. Can anyone suggest a source of little clamps and the like? (ie a widget catalog?) Thanks! Sydney |
I also have the Hood Lamb. I think it is the greatest view
limiting device I have ever tried. I also have two Sennheiser ANR headsets which like your Lightspeeds will not work with the Hood Lamb. May I suggest a very low tech but pragmatic solution? What headsets did you have before getting the ANRs? If you are like me and many others you probably had David Clarks are similar work alikes. Just reserect on of those and use it for IFR training. (Older ones are also available cheap because of the great movement towards ANRs). Like most people, I don't do hood flying for more than an hour or two at a stretch, so the slightly higher noise of the passive headsets is not really a problem. ~Paul We have Lightspeed headsets. ... I saw a cool product for IFR training which clipped onto the band of a headset with tiny little bands, and flipped up and down to limit one's view or move out of the way. It's called the Hood Lamb Unfortunately, it only fits on headsets with steel bands, like DC's or Sigtronics. |
I've had a hoodlamb since the early '90s, and I love it. It doesn't fit on my
DC headset (don't recall the number, but it is the one with a wide plastic toothed thing instead of stirrups). When I go for training, I just pull out one of the better pairs of sigtronics S20's and use them with the Hoodlamb. Figure I can put up with the headset for the couple of hours of training a year. I got the white hoodlamb, didn't care for the black one, got too dark inside. I also cut the horns off the bottom of the view port, it was too hard to read charts with them there. "Gary L. Drescher" wrote: That looks like a cool device. Thanks for posting the pointer! I've been dissatisfied with Foggles too, both because of the discomfort of putting the stems under the headset (I wear contacts instead of glasses, and use Shields sunglasses that have a string instead of stems, so only Foggles present this problem for me), and also because they don't really limit my outside vision adequately. I'd been meaning to try to find or devise some alternative, but so far this year I've been able to stay current just by shooting approaches in benign IFR, so I've kind of forgotten about the foggles. (Sorry, no idea about the widget catalog.) --Gary "Snowbird" wrote in message om... OK, I'd like to tap into the ingenuity of the group here. We have Lightspeed headsets. We use Foggles for simulated instrument training. I don't like it, because the earpieces of the Foggles create a sound gap. I saw a cool product for IFR training which clipped onto the band of a headset with tiny little bands, and flipped up and down to limit one's view or move out of the way. It's called the Hood Lamb (for example: http://www.pilotshop-usa.com/store/i...PARTMENT_ID=78 Unfortunately, it only fits on headsets with steel bands, like DC's or Sigtronics. It looked like something a clever chap ought to be able to duplicate with a bit of ingenuity, given the requisite parts -- some kind of swivel, and some kind of clamp which would fit the wider plastic band of the Lightspeed headsets. There is a clever chap in our house. Can anyone suggest a source of little clamps and the like? (ie a widget catalog?) Thanks! Sydney -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
"Snowbird" wrote in message om... I use the ASA clip to sunglasses, folding up/down view limiting device (overcasters). Light and cheap (though more expensive than they need to be for a piece of plastic - the joy of aviation), easy to flip on or off. And yes, I have an old frame with no lenses for "low light" flights. -- Bob PP-ASEL-IA, A/IGI |
Stan Gosnell wrote in message ...
My personal device is a flip-up type, which attaches to my glasses the way flip-up clipon sunglasses do. Yeah, I'm really tempted by these, but I prefer to wear contact lenses when flying for better peripheral vision. Our CFI doesn't like pilots he flies with to use hoods. Apparently he had a near-miss involving the blind spot they create. Can't argue with that. I know of one pilot who has made foggles from some wrap-around safety glasses That's what mine a old scratched-up safety glasses with an area of the lens taped over, then attacked w/ sandpaper and a dremel tool. For clamps, check the local home-improvement store or Sears hardware store. You'd be surprised at the stuff you can find there, if you spend some time looking. Didn't see anything juicy at Home Depot, but I'll check Sears and yeah, I coulda looked more and harder at Home Depot. Thanks for input, Stan. Cheers, Sydney |
"Paul Mennen" wrote in message ...
May I suggest a very low tech but pragmatic solution? What headsets did you have before getting the ANRs? Flightcom Eclipse. Even wider band and less chance of fitting than Lightspeed. So afraid your pragmatic solution won't work for me ![]() If you are like me and many others you probably had David Clarks I have a broad head (some might say "fat" heh heh) and Dave Clarks are "Dave Clamps" to me. I know people who own Dave Clamps but I don't think I could stick 'em, even for an hour .They'd make a good distraction though. Cheers, Sydney |
| Thread Tools | |
| Display Modes | |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Poly Dope Question | Michael | Home Built | 3 | January 29th 04 08:10 AM |
| Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 02:51 AM |
| Lightspeed -- Was:Oshkosh 2003 Redux | Jack McAdams | Home Built | 8 | August 14th 03 04:19 PM |
