Small window in Lexan
Old December 13th 05, 06:17 AM posted to rec.aviation.homebuilt
Default Small window in Lexan
Greetings group,
I desire to cut a small window (camera port etc) into a larger
Lexan side window/door in my Skyranger
Any and all advice re
framing the hole,
hinges to use,
latches,
over lap to seal wind,
and suitable size would be welcome.
I am thinking about a 200 * 150mm ( 8" * 6") inch window
many thanks
David Hill
Old December 13th 05, 03:22 PM posted to rec.aviation.homebuilt
framing the hole,
hinges to use,
latches,
David,
Here is a link that may be helpful.
http://www.soaridaho.com/Schreder/Co...ingwindow.html
HP-14 N990 "6F"
Old December 13th 05, 08:56 PM posted to rec.aviation.homebuilt
David,
When you are buying materials, make sure you get the right stuff. Most
aircraft glazing is acrylic and not Lexan. Even though Lexan is
superior in strength, it is not as clear, more flexible, and virtually
un-polishable. The glues etc. are different for each.
Old December 16th 05, 10:43 AM posted to rec.aviation.homebuilt
Everything that you need to know about this topic can be found in Section 3
"Transparent Plastics" in AC 43.13-1B/2A Acceptable Methods, Techniques, and
Practices; Aircraft Inspection, Repair & Alterations
You can have it on your shelf for $12.89 from Amazon
http://www.amazon.com/gp/product/156...books&v=glance
Here's a pointer to a pdf of the relevant section:
http://www.glapinc.com/instructions/...1BChapter3.pdf
- Russ
"DavidH" wrote in message
Greetings group,
framing the hole,
hinges to use,
latches,
many thanks
David Hill
Side window install Jim Burns Owning 3 August 11th 05 03:59 PM
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! Small Blue Planet Toys Aviation Marketplace 0 October 15th 03 05:26 PM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 12:19 PM
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble Small Blue Planet Toys Aviation Marketplace 0 July 11th 03 04:00 PM
