Metric Aircraft Nuts and Bolts
Old December 14th 05, 01:17 AM posted to rec.aviation.soaring
Default Metric Aircraft Nuts and Bolts
I am building a european glider kit. I am in need of some additional metric
aircraft bolts and nuts, something a grade higher than Home Depot. I have
had little luck finding information on what would be the metric equivalent
of US AN series hardware. I have been unsuccessful in determining what the
nomenclature is.
Can someone provide guidance on what I need to look for and any possible
sources?
Thanks
John Scott
Old December 14th 05, 03:09 AM posted to rec.aviation.soaring
nomenclature is.
sources?
Thanks
John Scott
John,
I don't know about aircraft grade metric hardware, but there is an
outfit that sells quality metric standard stuff. Try
http://www.metricmcc.com/
Good luck,
Uli Neumann
Libelle 'GM'
Old December 14th 05, 03:34 AM posted to rec.aviation.soaring
Hi John,
I don't know about European standards, but I have purchased many metric
screws and nuts from www.mcmaster.com
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"John Scott" wrote in message
metric aircraft bolts and nuts, something a grade higher than Home Depot. I
have had little luck finding information on what would be the metric
equivalent of US AN series hardware. I have been unsuccessful in
determining what the nomenclature is.
sources?
Thanks
John Scott
Old December 14th 05, 05:37 AM posted to rec.aviation.soaring
Look locally for a Fastenal store.
http://www.fastenal.com/web/home.ex
Tim
Old December 14th 05, 10:48 AM posted to rec.aviation.soaring
You could try www.friebe-luftfahrtbedarf.de in Germany for aircraft quality
parts if you can´t find
other sources in your country.
Nomeclature ist easy, M8 x 30 - 12.9 for example means
M ... Metric standard thread
8..... diameter is 8mm
30...length 30mm
12.9 means 1200N/mm˛ ultimate tensile strength, and a yield strength of 90%
of UTS.
Michael
Old December 14th 05, 04:20 PM posted to rec.aviation.soaring
30...length 30mm
of UTS.
Michael
What grade/s of fasteners are considered to be aircraft
quality in Germany?
Old December 14th 05, 08:54 PM posted to rec.aviation.soaring
nomenclature is.
sources?
Thanks
John Scott
Try the nice folks at INACO.
They are a small aircraft hardware supplier located in San Antonio.
They are pretty receptive to small orders so, if they can, they'll be
eager to try to help you out.
Inaco Inc
130 Braniff Dr
San Antonio, TX 78216-3301
(210) 344-8711
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Buying Junk from Aircraft Spruce --- Or Putting Money Down a Rathole jls Home Built 41 February 5th 05 08:04 AM
Cessna buyers in So. Cal. beware ! Bill Berle Owning 92 June 26th 04 03:24 PM
