Curtis quick drain
Old December 24th 05, 06:25 AM posted to rec.aviation.homebuilt
Default Curtis quick drain
Mine started leaking after 20 years of service, not a bad service life for
something that I can replace for less than $10 at aircraft Spruce, or $14
from Sacramento Sky ranch. But since it is brass and looks to be in great
shape, I would just like to replace it's rubber seal. I thought it was an
o-ring, but it is a tiny rubber washer. I found what I thought was the
perfect replacement from Mc Master Carr, had to order 100 of them. Sadly
they do not fit. I asked the FBO guys next door and they said they used to
be able to order the seals but they can't get them any more. BTW the new
valve that I ordered from Spruce will be here next week.
Does anyone know of a source of just the seals?
Thanks for any info or suggestions.
Old December 26th 05, 02:50 AM posted to rec.aviation.homebuilt
I heard that some idiot installed a seal incorrectly and drained all the
fuel out of his tank so Curtis doesn't want the
liability so they don't sell replacement parts.
"keepitrunning" wrote in message
to be able to order the seals but they can't get them any more. BTW the
new valve that I ordered from Spruce will be here next week.
Quick drain mess. dlevy Owning 10 October 17th 05 01:55 AM
Spider in Archer Sump Drain Bob Chilcoat Owning 3 June 29th 05 10:29 PM
QUICK EASY CASH [email protected] Owning 1 April 20th 05 07:18 PM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
sump drain cleaning Mike Noel Owning 15 August 15th 03 02:41 AM
