The Man Who Couldn't Cleco
Old December 27th 05, 05:26 PM posted to rec.aviation.homebuilt
Default The Man Who Couldn't Cleco
Needing some high-strength 7/16ths bolts, over the holidays I visited
one of the unofficial RV assembly plants here in San Diego county.
Located in an industrial park adjacent to the airport, the fellow has
set-up permanent fixtures just like a real aircraft factory, allowing
him to assemble an RV with perfect accuracy in remarkably little time.
RV's use NAS bolts to hold the wings on and I'd come a'begging.
He had a new helper, a guy about my age. He was over at the
leading-edge fixture, struggling to install a cleco. From his body
language I guessed the thing was bent. I would have tossed it but he
kept wrestling with it, finally got it in and went on to the next. But
damned if he didn't do the same thing.
I found my friend in his cubby hole, told him what I was after, showed
him what I had to trade. He poked around in his cabinets, found what I
needed and gave me four. Looking past me he saw the fellow working on
the leading edge. Heaved a big sigh and shook his head. The guy was
struggling with yet another cleco.
"Somebody bend all your clecos?" I asked.
My friend gave a bark of laughter. "There's nothing wrong with the
clecos," he said shaking his head. We both watched the guy. He
finally got it in, flexed his hand and started doing an other in the
same awkward manner. We watched him put in three then the fellow must
of sensed he was being watched because he looked up.
"He doesn't know how to cleco," I said in surprise.
"Yeah," my friend agreed. He told me how the fellow was
ex-military, had his ticket and a zillion years experience. "But
nobody ever showed him how to set a cleco," he sighed.
I tucked my bolts in my pocket and got the hell outta there, not
wanting to be around when my friend, who was never in the military and
isn't an A&P, tried to explain to a card-carrying sixty year old A&P
that he doesn't know how to cleco.
I can't remember how old I was when my dad let me help him rivet.
About nine, I think. Unless you're using PK's, knowing how to
cleco is a required part of knowing how to rivet.
Clecos are spring-loaded temporary fasteners. They get inserted
through the hole where the rivet goes and serve to hold the parts in
alignment for drilling and riveting. Once everything is aligned, you
set rivets in the holes between the clecos, then remove the clecos and
set a rivet in that hole too. The cleco is installed and removed with
a pair of special pliers referred to as forceps in the trade. Because
of the spring, it takes a certain amount of strength to use them. But
not much, as shown by Rosy the Riveter and her million sisters.
To use clecos, you insert the tang into the hole, press the cleco flush
against the visible part then squeeze the handles whilst maintaining a
moderate amount of pressure on the cleco. The pair of shaped wires are
squeezed past the tang and through the hole in the INVISIBLE part with
a slight click, telling you it's okay to relax your grip and go on to
the next one. Doing a panel, you'll have a handful of clecos in one
hand, the forceps in the other, shooting a cleco into every third or
fourth hole at the rate of about one every five seconds or less. Do it
right, it takes just that one, quick squeeze. Since you aren't
trying to hold the cleco compressed, and since you only have to
compress it far enough to let the shaped wires through the hole, it
doesn't take a lot of strength - - even a kid can do it.
What the fellow at the RV factory was doing was putting a cleco into
the forceps then squeezing until the locking wires were fully extended.
Holding it with the spring fully compressed, he was trying to fly the
pair of locking wires through the hole in the two layers of metal,
which he eventually did. But he was spending a minute or more per
cleco. In the time he took to do one row a real tin-bender would have
secured the entire panel.
I've reached an age where I'm no longer surprised at the things
people don't know but should. My visit to the RV factory showed me
yet another reason why some folks think riveting is hard. And why
others take years to complete a six-month project.
-R.S.Hoover
PS - PK's are hex-head sheet-metal screws fitted with a non-marring
washer. That what we used before clecos came along.
Old December 27th 05, 09:56 PM posted to rec.aviation.homebuilt
Sounds like an aircraft factory to me. The products of that factory
are not "homebuilts" and the FAA is failing to do its job by allowing
said aircraft to be certificated as Experimental Amateur-Built.
Dick van Grunsven knows this is going on. He knows it isn't really
right. but I don't blame Dick even though he is becoming a
multimillionaire from this scam. I blame the FAA.
Homebuilts should be that, built in one's domicile or in a
single-ooccupant wholly owned area with the builder a _nonprofessional_
aircraft constructor. An A&P should not be allowed to touch a homebuilt
unless he is also a pilot and can testify under oath it is for his
personal use and will not be sold, at least for some period of time.
If you want to be in the business of building aircraft, you should be
building a type-certificated aircraft. Else, why have such a thing at
all? Get rid of type certification entirely.
Either type certification is good or it is bad. Let's poop or get out
of the outhouse instead of allowing a kitchen business of foolish old
farts to mess with progress. Especially since they are not interested
in educating anyone else, expanding aviation, or developing the
technology.
Old December 27th 05, 10:20 PM posted to rec.aviation.homebuilt
"Bret Ludwig" wrote in message
Plonk!
Rich S.
Old December 28th 05, 12:37 AM posted to rec.aviation.homebuilt
Thanks again Hoover.
Old December 28th 05, 01:45 AM posted to rec.aviation.homebuilt
-R.S.Hoover
I respect and read everything you write and I know that you have a great
amount of knowledge, so here it comes "BUT." :-) I built my whole RV-6
using the method that you say the guy was doing wrong and I can tell you
from experience of setting around 12,000 to 14,000 rivets myself that
method works just fine. In fact I will work along side your method
anytime and keep up with you if not be a little faster. I cannot see
where your method is any better than the other way. When the cleco
pliers depress the cleco the two protruding wires come together and it
is easy to slip the cleco into the hole. IMO of course. :-)
Jerry(flying my old RV-6 for to 17 years) Springer
Old December 28th 05, 06:04 AM posted to rec.aviation.homebuilt
PS - PK's are hex-head sheet-metal screws fitted with a non-marring washer. That what we used before clecos came along.
Hoover,
Do I have to 'smooth out' the hole after removing the PK's before
putting in the rivets? I'd think that the various 'cuts' in the
material due to the PK's might be a good starting point for a crack/rip
to develope.
The Monk
Old December 29th 05, 07:05 PM posted to rec.aviation.homebuilt
"Forceps"???...what the hell are "FORCEPS"???
I been in the "trade" for 30 years and I never heard of nuttin called
forceps!!!...that had anything to do with cleco's...
....wait a minute. You talkin' 'bout Cleco pliers???...you know... the cleco
pliers you put the cleco's in with...that wut your callin a "forcep"?
Ohhhh...I admit...ahm' a little slow on them big wurds.
Dr. Dave (in his "other" trade) :-)
-R.S.Hoover
Old December 30th 05, 03:51 AM posted to rec.aviation.homebuilt
I'm willing to wager that you were never in the Navy. I know Bob was &
I have heard other Navy guys call them forceps. Different lingo in
different circles. Given theat the tool isn't used to ply anything,
forceps might even be a more accurate term. Sorry that the world
doesn't conform to your expectations.
Daniel
Old December 31st 05, 01:10 PM posted to rec.aviation.homebuilt
Daniel
If someone at work ask to borrow my forceps, he or she would get a deer in
the headlight look. However, third drawer down on the right is my CLECO
pliers. Oh yeah, 23 years in the NAVY.
