DP Question
Old September 7th 03, 02:39 PM
My name
Default DP Question
Hello. I am an IFR student (near the end- Last stage check of a Part
141).
I have a question about a DP.
The GATEWAY FOUR DP from CPS (E. St. Louis) has a note "For Turbojet
aircraft only".
Can this DP be used (voluntarily) for piston a/c? On this particular DP,
altitudes only call "Climb/Maintain 2500 or assigned. EFC to filed in 10
min." There are no similar DP for piston a/c.
I had been taught that if there is a DP that you can comply with, you
should
file it (i.e. GATWY4.BIB V12 ..etc).
Opinions?
Larry
Old September 8th 03, 02:30 AM
Ron Rosenfeld
141).
aircraft only".
should
Opinions?
Larry
This is only an opinion (that's what you asked for).
You can file whatever you want.
However, since the procedure says For Turbojets Only, ATC will probably not
clear you this way in a small GA a/c. You'd interfere with the faster
turbojets.
If I wanted to go in that direction, I'd probably just file VOR's, airways,
and/or direct routings.
There is no requirement to FILE a DP, whether or not you can comply with
it.
Newbie Question, really: That first flight Cecil Chapman Home Built 25 September 20th 04 05:52 AM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
