Fuzzy Logic
Old January 6th 06, 06:18 AM posted to rec.aviation.soaring
Default Fuzzy Logic
Tony Verhulst said,
'Ok, answer C says
'The best lift/drag speed with no regard to wind velocity.'.
So, Tony's best lift/drag speed is 50 knots and I'm
flying into a 50 knot
headwind at 50 indicated. And, I'm going ... where?
'A' is the correct
answer, IMHO. Answer 'A', in the above example, would
get you a ground
speed of 25 knots (75 - 50)- you're not going to do
much better than
that. The question, though, is poorly worded.
Tony V.
\_____________________________________________
Hi Tony,
re gittin the mostest out of the leastest into the
winds
when in a gliduh.
'Splain yo comment pls.
I thougjht best L/D into wind was defined to be Still
Air Best L over D speed plus half of the headwind speed
or plus the headwind speed.
What think you?
And, further, it seems one must size up the glide
angle
and impacting or landing site as one goes,
seeking to get best options made for landing .
Legitimate Question:
Is this art, craft, or science? given to addressing
this situation,
or all of the foregoing?
I say,
Fuzzy Logic Rules.
Adapt, adjust, use an estimated set of perameters,
thence
adjust to best outcome considering the difficulty one
finds oneself in and changing facts at hand and in
the changing situation
in his
Gliderplane.
Dancing on clouds,
Keep it up!
Jim Culp, USA
GatorCity Florida
Asw-20C
Old January 6th 06, 12:35 PM posted to rec.aviation.soaring
Default Fuzzy Logic
Interesting case with a 50 knot wind, but you forgot to factor in the
tiny detail that with a 50 knot wind, the thermal (assuming it isn't
sheared to bits) is coming at you at 50 knots. If you're looking for
interthermal cruise then wind speed does not factor into the
calculation, only if you're looking for performance relative to the
ground. The question appears to be talking about interthermal. If you
fly faster, you'll just arrive at that next thermal lower. D'oh!
Jim Culp wrote:
Tony Verhulst said,
'Ok, answer C says
'A' is the correct
get you a ground
much better than
Tony V.
Hi Tony,
winds
when in a gliduh.
What think you?
angle
this situation,
I say,
Fuzzy Logic Rules.
thence
in his
Gliderplane.
Dancing on clouds,
Keep it up!
Jim Culp, USA
GatorCity Florida
Asw-20C
Old January 8th 06, 10:19 AM posted to rec.aviation.soaring
Default Fuzzy Logic
Is flying an exact science?
Would it be better if we use correct terminology?
L/D is L/D.
L/D is Lift to Drag Ratio.
L/D is not effected by Wind.
Glider + effect of Wind = RANGE
L/D is a number without Wind.
Wind changes L/D into RANGE.
L/D+Wind effect is not different L/D, or best L/D, but becomes "RANGE".
kapich or kaput.
CFIRocket
BRAC Logic....NAS Brunswick Andrew C. Toppan Naval Aviation 45 May 21st 05 04:31 AM
logic of IO-360 100hr injector inspection 93-02-05 Robert M. Gary Piloting 2 November 30th 04 04:13 PM
"Why Raptor? The Logic of Buying the World's Best Fighter" Mike Military Aviation 0 August 11th 04 03:20 PM
Logic behind day VFR Dillon Pyron Home Built 8 April 1st 04 04:00 AM
Airport Identifier Logic Jay Honeck Piloting 17 August 14th 03 06:58 PM
