Cessna landing light switch
Old January 11th 06, 09:32 PM posted to rec.aviation.owning
Default Cessna landing light switch
I have a C-172B that has the dual landing lights in the wing. The first
position on the pull-out light switch turns on only the taxi light (at
least I assume it is for taxi as it is aimed so low) and the next
position turns on both (landing and taxi). Does anyone know if there is
a legal replacement pull switch that will turn on one or the other but
not both? I'm thinking I could cut such a large and unnecessary power
drain while the engine is usually at idle during descents. (Adding all
those other bells and whistles over the years is beginning to show the
need for some power conservation in other areas) Thanks in advance.
Old January 12th 06, 12:19 PM posted to rec.aviation.owning
Seems like just the taxi light should be sufficient during a long
descent at low power... What do you expect to see at 3000 feet, or
whatever? I only turn a light on that high up so others can see me...
And, landing lights are vastly over rated as far as usefullness...
There have been studies that show that leaving the landing lights off
and using the runway lighting gives better depth perception...
Now, having talked all around the subject, no I don't know of a 'legal'
replacement switch that will give you only separate lights because even
if it were 'legal' in another airplane it won't be 'legal' in yours
because it wasn't certified with that style of switch... So, my best
advice is for you to find a switch that will fit, and will operate the
way you want, change it out yourself, and move on...
denny
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 05:39 AM
Landing Light CB Hankal Owning 25 August 25th 04 02:22 AM
C-172 landing light switch JFLEISC Owning 10 May 5th 04 11:05 PM
Cessna landing gear legs Reserve MET! Bill Berle Home Built 1 February 23rd 04 12:31 AM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Home Built 0 February 19th 04 06:51 PM
