I had asked if anyone knew of a replacement Cessna landing light switch
that would turn on the taxi light and landing light separately (not both on the second pull-out notch so as to ease the electrical load during low RPM). I had given up and was going to take Denny's advice to remove the existing switch to be replaced with whatever I could find, not necessarily certified, that would work. Well guess what; the existing switch had an extra unused post on it. Seems Cessna, in its apparent wisdom, made the switch configurable to either setup. All I had to do was put the taxi light lead on the other post and I had just what I was looking for. Why can't all problems be this easy? |
I guess I missed that post. My 67 182 had a split landing/taxi light
switch. They look just like the split master/alternator switch except they aren't red. You can get those from Cessna or any number of other places. jim wrote: I had asked if anyone knew of a replacement Cessna landing light switch that would turn on the taxi light and landing light separately (not both on the second pull-out notch so as to ease the electrical load during low RPM). I had given up and was going to take Denny's advice to remove the existing switch to be replaced with whatever I could find, not necessarily certified, that would work. Well guess what; the existing switch had an extra unused post on it. Seems Cessna, in its apparent wisdom, made the switch configurable to either setup. All I had to do was put the taxi light lead on the other post and I had just what I was looking for. Why can't all problems be this easy? |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
Cessna landing gear legs Reserve MET! | Bill Berle | Home Built | 1 | February 23rd 04 12:31 AM |
Cessna Steel Landing Gears, J-3 Seat Sling For Auction | Bill Berle | Home Built | 0 | February 19th 04 06:51 PM |
Cessna Steel Landing Gears, J-3 Seat Sling For Auction | Bill Berle | Aviation Marketplace | 0 | February 19th 04 06:51 PM |
