engine choices
Old January 21st 06, 01:24 AM posted to rec.aviation.homebuilt
Default engine choices
I saw one post about evinrude marine motors being used for aircraft, and
issues due to water cooling.
has there been other engines that have been used? say snomobile engines? A
freind of mine has a evinrude snomobile engine that he thinks might work. I
think otherwise
Old January 21st 06, 02:48 AM posted to rec.aviation.homebuilt
"Tater Schuld" wrote in message
I
think otherwise
What otherwise do ya think there Tater?
Old January 21st 06, 04:14 PM posted to rec.aviation.homebuilt
"karel" wrote in message
"Tater Schuld" schreef in bericht
A freind of mine has a evinrude snomobile engine that he thinks might
work. I think otherwise
There's one execellent snowmobile engine conversion, it's called a Rotax.
I wasnt sure but i thought there was a snomobile tht used rotax engines.
didn't want to show my ignorance.
why only one engine conversion? have evinrude come up with a similar unit,
charge 10% less than rotax, and clean up in a new market!
Old January 21st 06, 04:48 PM posted to rec.aviation.homebuilt
Evinrude and Rotax are both owned by Bombardier Recreational Products Inc.
news
engines?
Rotax.
Old January 29th 06, 02:02 AM posted to rec.aviation.homebuilt
"Lakeview Bill" wrote in message
om...
Yeah, i assumed so. I didn't want to blurt it out if i was wrong tho.....
anyway, I talked to a few snomobilers in the area, and they say that a 60hp
engine shouldnt cost more than $500 NEW, maybe $300 used.
add a redrive and I *should* be go, right?
(i know I am wrong, i want you to tell me WHY i am wrong)
Old January 30th 06, 01:19 AM posted to rec.aviation.homebuilt
om...
The Rotax two cycle snowmobile style engines sold for ultralight use
were upgraded versions and have fallen out of favor due to seizures,
even with liquid cooled versions. My guess is the redrives were set up
to not easily go on to the commodity snowmobile engine either. I
haven't seen a two cycle anything in the pattern over my house in
years: we had several Avid Flyers and Kitfoxes buzzing overhead in the
late 80s and early 90s. Now we have T-6s and L-39s! We've yupscaled.
Most people want to get as far away from two cycle power as possible.
I never understood why the Mazda rotary is not used in outboard
engines. I know some Honda outboards use an automotive engine core, and
that at one time there were licensing issues with the Wnakel patents
restricting Toyo Kogyo from industrial sales. Those patents are now
long since history.
Old January 30th 06, 03:27 AM posted to rec.aviation.homebuilt
We have an eclectic mix of VW and two-stroke around here.
I've flown a few of each - mostly draggy parasols (natch).
The V-dub's mighty roar is a lot of fun.
Reliability-wise, I think it depends a lot on the individual airplane.
Not just how well the thing is built, but also how well powered it is.
You see, I've come _not_ to believe in under powered homebuilts.
They are just not that much fun. Unfortunately.
I've never flown a 1600 that I was really comfortable in.
The engine blaring out 90 to 95 percent just to maintain altitude?
If you can't hear that engine straining, then you have no machine
in your soul.
The 1835 is a different story. There's enough there to throttle
back and find a sweet spot. Enough prop to climb well.
Considering what it costs to build one, the 1835 should be *the* VW.
The 2180 is a sweet thing. Loaf along at 3 GPH? Or Roar up at the clouds.
But..
Fully dressed with accessory case, Bendex mag, electric start, 20 Amp
alternator = 205 pounds? And an expensive thing by comparison.
Robert Padget (Zuehl) built a little 1/2 VW parasol that actually flew.
I never got to fly is, but I saw it fly quite often.
900 some CC. And Robert is often called Big Bob, because he is.
It flew well. Vibrated like hell over most of the RPM range.
But you kind of have to expect that.
Now, with my current medical situation, caught in the catch 22 of the
Sport Pilot rules...
I've been thinking about the smooth immediate power of a Rotax 503. Again.
Just as a practical solution to getting back in the air.
That 254 pound weight limit is a (explicative deleted) tough one.
But with a Rotax 2 stroke on it, looks like it, sounds like it, and smells
like it... fly it!
Richard
Old January 30th 06, 06:41 AM posted to rec.aviation.homebuilt
"Richard Lamb" wrote in message
nk.net...
First, calling a Rotax 582 a "snowmobile engine" is misleading. They were
(and are) sold specifically as aircraft engines, they put out around 65 HP,
and they had several upgrades internal to them (better wrist pin bearings
was one). The new price was around $5000. The snowmobile version of the same
engine (the 583) had around 90 hp, showing how much Rotax gave up in an
attempt to upgrade reliability..
The reason there was (is) such a reliability problem has to do with
carburetion. Several things that you'd never expect were common failure
modes. I remember the following:
The engine would shake so badly it'd foam the fuel in the float bowl - not
enough fuel getting to the engine caused a lean mixture, lean mixture causes
overheating, overheating causes the pistons to expand until they're bigger
than the bore. Pistons would seize. If you succeeded in landing, you'd find
the (now cool) engine would start and run fine. Get a pair of clean shorts,
then go back up?!??
This could happen other ways as well. The common thread was the thing goes
lean and seizes. Right in the operators manual, it says that the thing may
stop without warning. I had it drilled into me by my (now dead) flight
instructor that you "never fly over anything you can't land on."
The new snowmobile engines don't do that. Fuel injection is not subject to
such things - and if it does see the temp headed for trouble, it'll throttle
back - not die completely. My new Polaris Fusion 900 snowmobile (
http://www.polarisindustries.com/en-...nce/900Fusion/ )
has an engine that weighs less than a Rotax 582, puts out 150 hp, and is
fuel injected by a mature reliable design. It will also do 135 mph on
Harding lake from now 'till the spring thaw!
The only thing stopping me from ripping it out of the snowmobile and
mounting it on my kitfox clone is money, and a strong paternal feeling for
the snowbound F-16 fighter it's in now ;^}
Old January 30th 06, 05:09 PM posted to rec.aviation.homebuilt
"Ron Webb" wrote in message
nk.net...
HP,
don't recall him referring to the 582s in particluar. just that snomobile
engines were used for ultralights
Old January 30th 06, 05:12 PM posted to rec.aviation.homebuilt
nk.net...
throttle back - not die completely. My new Polaris Fusion 900 snowmobile
yeah, i saw some of those. about the same price as an ultralight kit w/o
motor, or sometimes with.
if I had the choice between a snomobile and an ultralight, i'd go fly. right
now neigther option is available yet (YET!) so all i can do is speculate and
window shop.
Centurion FAQ with kibbitzing Bret Ludwig Home Built 0 November 12th 05 10:39 PM
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
