Can all HSI's be slaved -- should they be?
Old February 3rd 06, 02:44 AM posted to rec.aviation.owning
Default Can all HSI's be slaved -- should they be?
Hello,
I'm just reading up on HSI's and I notice some planes have HSI's that
are not slaved. I know this means i'm supposed to check it every 15
minutes or so to make sure the HSI and the compass jive. I guess I
should still do that even if it was slaved... but what I am wondering
is if you can make a non-slaved HSI slaved by buying the additional
equipment. Or are certain HSIs not slaveable and thus would i need to
get a new HSI if I want a slaved one?
-dr
Old February 3rd 06, 12:22 PM posted to rec.aviation.owning
Moving map GPS is making the HSI the buggy whip of the 21st century...
Having noted that I am old school who enjoys using an RMI / HSI and vor
navigating to an ILS approach... Like the dodo I will be gone soon,
also...
Whether an HSI head can be slaved depends on the exact model... Check
with the radio shop on a given airplane...
denny
Old February 3rd 06, 01:02 PM posted to rec.aviation.owning
Denny wrote:
: Moving map GPS is making the HSI the buggy whip of the 21st century...
: Having noted that I am old school who enjoys using an RMI / HSI and vor
: navigating to an ILS approach... Like the dodo I will be gone soon,
: also...
: Whether an HSI head can be slaved depends on the exact model... Check
: with the radio shop on a given airplane...
When the installed price of a moving map IFR GPS is a large fraction of the
value of the plane, going old-school still makes a lot of sense. I'm a big believer
in bang/buck, and blowing $10K for a GPS on a $35K airplane does NOT make sense.
-Cory (PA-28-140/180 driver)
* Cory Papenfuss *
Old February 3rd 06, 03:10 PM posted to rec.aviation.owning
Not all HS's are slaved. Slaving the DG portion of an HSI is not
necessary for an HSI to function. Having said that, MOST HSI's ARE
slaved. Slaving is a major expense on an HSI. There used to be slaved
DG's around, dont see them anymore.
Old February 3rd 06, 03:21 PM posted to rec.aviation.owning
: How do you feel about blowing $10K, $2K at a time as you repeatedly repair your
: electromechanical moving map (HSI)? Well, OK, maybe a slight exaggeration, and
: of course there's no subscription cost for the HSI.
: Anyway, the HSI presentation is compelling. I like the HSI-style presentation on
: my GNS480. Sometimes it's more informative than looking at the map page.
: In the larger view, electromechanical HSIs are the equivalent of buggy-whips.
I'll agree with that. I was referring more generally to normal old-school
(VOR-indicator, DME, etc).. not the fancier old-school like remote slaved compasses,
HSI's, etc. Those *are* electromechanical nightmares to keep running. Something like
a VOR/GS indicator isn't that complicated. It also doesn't have a subscription....
Just as an aside, many of the moving maps that I've seen are much more
difficult to follow accurately than old-school methods. I'm sure it can be done well
(I just haven't seen it). As a quick, "reset-your-situational-awareness," or to
visually see things like airspace boundaries, moving-maps are wonderful. To keep the
needle centered on an airway or LOC, they're useless without augmentation.
-Cory
* Cory Papenfuss *
Old February 4th 06, 03:14 PM posted to rec.aviation.owning
wrote in message ...
Useless?
Intercept the purple line, keep it vertical. Zoom in if you want to be EXACT.
I'm sorry, I guess I miss your point!
Cheers,
John Clonts
Temple, Texas
N7NZ
