Tachometer Cable
Old February 4th 06, 03:47 PM posted to rec.aviation.owning
Default Tachometer Cable
Hello everyone,
I had a situation where my tachometer cable came loose at the tachometer. I
reattched it as tight as I could be hand and is holding so far. I wanted to
know if I should try and tighten it more using pliers, or could that cause
damage. Or is it common practice to apply something to the threads to
assure it holds?
There isn't much room behind there to work.
SAC
Old February 4th 06, 05:57 PM posted to rec.aviation.owning
In article h04Ff.532627$084.273679@attbi_s22,
"SAC" wrote:
Hello everyone,
assure it holds?
SAC
Take it out; take it down to your closest speedometer shop and have them
duplicate it; install the new one in your plane.
Remve "_" from email to reply to me personally.
Old February 6th 06, 09:23 PM posted to rec.aviation.owning
There is thread locking compound available at your local auto parts
store. "Locktite"
Made for just such a situation. Holds strong but allows for removal.
Old February 9th 06, 01:38 AM posted to rec.aviation.owning
On Sat, 04 Feb 2006 15:47:26 GMT, "SAC"
Hello everyone,
assure it holds?
SAC
I'd get a pair of pliers on it, and just cinch it down a little bit
more than you could get by hand. Not a big fan of the Locktite
approach. Once tight it should hold, unless there is something else
wrong.
z
nicopress sleeve for stainless steel cable ls Home Built 3 December 6th 05 04:09 PM
Helicopter knocks out cable car, killing nine. Flyingmonk Piloting 12 September 16th 05 12:27 AM
Stuck cowl flap cable Jim Burns Owning 7 March 24th 05 02:07 PM
Best lubricant for Mechanical Tachometer Cable??? RonLee Home Built 3 January 4th 05 12:04 AM
Tachometer or Tach Cable Rich Owning 14 October 14th 04 02:54 AM
