Backing up WinPilot
Old February 11th 06, 01:13 AM posted to rec.aviation.soaring
Default Backing up WinPilot
Is there a way to maintains two IPAQs to be identical with WinPilot? I
would like to set up a primary unit, with the second unit as a backup
in case the first one fails. I have found that just copying files does
not work. The settings files are not duplicated in this way. I have
two IPAQ 3950's.
Tim
Old February 11th 06, 02:15 AM posted to rec.aviation.soaring
Tim,
Short answer: no. From my experience you have to maintain them
separately. The best thing to do is maintain a copy of the settings
file (it's something like WP_SETTINGS.XML), and if you have to switch
to the backup, copy that file to "\My Documents" on the iPAQ using
ActiveSync, or from an SD or CF card.
(Also make sure that you make regular backups of both units using iPAQ
Backup, and specify external storage (SD or CF) for the backup files.)
~ted/2NO
Old February 11th 06, 02:20 AM posted to rec.aviation.soaring
p.s. an iPAQ Backup file created on one iPAQ cannot be used on another.
Old February 11th 06, 07:48 PM posted to rec.aviation.soaring
Use GPS_LOG. It has a backup applet.
Bob
Old February 14th 06, 02:56 PM posted to rec.aviation.soaring
Tim:
I have two 3635s and backing up one and restoring into the other works
without any problem. Both iPAQs run exactly the same OS version and
build.
I do not know if this woud work on a 3900 but I would try... what the
worst that can happen...
Regards
Enrique
two IPAQ 3950's.
Tim
Old February 14th 06, 05:44 PM posted to rec.aviation.soaring
Thanks for the feedback. I am getting a flash card to try the direct
backup, but is that fails I will work on just transferring the settings
files and see if I can get that to work. I just got these to replace
the 3700 series unit I used last year.
Tim
Old February 14th 06, 09:20 PM posted to rec.aviation.soaring
two IPAQ 3950's.
Is it possible to put Winpilot on just the SD card, then transfer that
between the units? Duplicating another SD card wouldn't be hard if you
wanted total redundancy.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
WinPilot shorts on PocketPC screen [email protected] Soaring 6 January 21st 06 08:56 AM
Winpilot Questions Mal Soaring 2 October 18th 05 10:19 PM
WinPilot offer... and UK news Paul Crabb Soaring 2 February 19th 04 09:22 AM
WinPilot Offers Free WinPilot XP for your Desktop Computer Richard Pfiffner Soaring 0 November 8th 03 04:44 PM
Declaring a flight in WinPilot to the Volkslogger JohnD Soaring 0 October 1st 03 11:55 PM
