I recall George Braly saying that they had done ground tests, using a
Chadwick-Helmuth vibration analyzer, with and without GAMIs - showing less vibration at lean mixtures with the GAMIs, several years ago. This is consistent with the wisdom that running lean of peak in an unbalanced engine, the cylinders are putting out different amounts of power - because in this regime the cylinder powers are directly proportional to the (unequal) cylinder fuel flows. Ed |
![]() wrote in message oups.com... I recall George Braly saying that they had done ground tests, using a Chadwick-Helmuth vibration analyzer, with and without GAMIs - showing less vibration at lean mixtures with the GAMIs, several years ago. This is consistent with the wisdom that running lean of peak in an unbalanced engine, the cylinders are putting out different amounts of power - because in this regime the cylinder powers are directly proportional to the (unequal) cylinder fuel flows. Quite. One thing many people miss about LOP is it not only reduced fuel usage (around 20%) but how much better the combustion event treats the engine components. |
![]() "Jim Macklin" wrote in message news:awuKf.101360$4l5.6971@dukeread05... http://www.nar-associates.com/techni...ion/Vibnet.pdf Not a word about misfiring cylinders. Nor how fuel injections are "calibrated". And running rich to reduce vibration (I notice they did not do a dynamic machine test for vibration), again, puts your engine in the worst possible condition for fouling, internal pressure, valve damage... Lycoming FI's are pretty close, but still have a hell of a lot of "slop". |
Scientific Data on Engine Operations | O. Sami Saydjari | Owning | 31 | July 29th 05 04:38 PM |
Rotating Injectors Among Cylinders | O. Sami Saydjari | Owning | 21 | July 15th 05 08:28 AM |
LOP operation | Roger Long | Piloting | 35 | April 17th 04 05:29 AM |
