Garmin 430 question
Old November 30th 03, 03:06 PM
smf
Default Garmin 430 question
With a waypoint on my 430 and pressing the OBS button my 430 draws a
"radial". The radial that is on the obs indicator.
What i don't understand is why the radial showing on the display is white
and not magenta? The reciprical of the radial is magenta.
Shouldn't it be the other way around?
Thanks
Steve
Old November 30th 03, 04:07 PM
SD Thomson
Steve,
I'm probably stating the obvious here, but I think the magenta line is "to"
and the white line is "from". I often use the OBS for vfr approach,
especially going to a new field. So if the rwy is 27 and assuming i'm
generally east of the airport, I set the obs to 27
and intercept the magenta line (now i'm on the 27 radial to the field --
and the 90 radial from the field)
Maybe this helps.
Stuart
"smf" wrote in message
news:XHnyb.45903$yJ.4001@okepread02...
Thanks
Steve
Old November 30th 03, 08:10 PM
Jeff
Stuart
are you using an HSI or a normal nav head?
my 430 drives my HSI, anytime I select OBS the HSI control the white line, you
move the HSI and the line moves. Its going to take me a while to get that
figured out correctly.
Jeff
SD Thomson wrote:
Steve,
Maybe this helps.
Stuart
Thanks
Steve
Old December 1st 03, 12:17 AM
SD Thomson
Jeff
I've got the garmin CDI, so I'm not really sure how the OBS function should
work with an HSI. Have you downloaded the Garmin 400 Series Simulator? (If
you bought the unit it should have been included with the documentation -- I
also got a pretty informative video)
The simulator incorporates an HSI. I played around with it and it seems
that if I set the OBS to the same general course as the waypoint, I get a
magenta line.
Stuart
"Jeff" wrote in message
Stuart
you
Jeff
SD Thomson wrote:
Steve,
"to"
field --
Maybe this helps.
Stuart
white
Thanks
Steve
Old December 1st 03, 03:03 AM
Jeff
yes I have the CD and play with it, but I hate using my mouse to click the
knobs...
I dont use the OBS at all (so far), I leave it in GPS mode and put the HSI on
the heading that the 430 says and the auto pilot flies the line perfectly...love
it...I had the garmin nav head in my last plane, the HSI is so much better.
Jeff
SD Thomson wrote:
Jeff
magenta line.
Stuart
Stuart
you
Jeff
SD Thomson wrote:
Steve,
"to"
field --
Maybe this helps.
Stuart
white
Thanks
Steve
Question on Garmin GNC 250XL Ron Home Built 1 October 24th 04 08:26 AM
Garmin Specials ADV Michael Coates Home Built 0 March 18th 04 12:24 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
"Stand Alone" Boxes (Garmin 430) - Sole means of navigation - legal? Richard Instrument Flight Rules 20 September 30th 03 02:13 PM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
