Left Mag Dead... After Annual???
Old February 27th 06, 04:49 PM posted to rec.aviation.owning
Default Left Mag Dead... After Annual???
So I just got out of a $1900 annual, and stopped by, on Friday, to gas
the plane up for a flight to happen this week... I tried to start the
plane up (Cessna 172), and it never as much as sputtered. The battery
was well charged and it turned over, and over, and over, and over...
Never fired though!?!? I tried for about 5 minutes, and ended up just
leaving it, for the mechanic to look at.
I called this morning, and they are still looking at it. He said, for
some reason, the left mag is dead. He's supposed to call me this
afternoon, when he has something definitive.
I've never had a problem starting this plane (with the exception of a
low battery), and was quite surprised to encounter something like that,
immediately after an annual... It would have been different, if it had
occured during regular useage, but when you go to pick up your airplane
from annual, you are expecting it to be in as tip-top shape as it can
be.
Has anyone else had a similar problem? The mechanic said the plane was
started and running after annual, so is this just a major coincidence?
Is it true??? Are we all just test pilots, when we pick our planes up
from an annual?
Thanks for any input.
Todd
Old February 27th 06, 05:07 PM posted to rec.aviation.owning
Yesterday I watched a C150 go out of a local shop after an annual. The
owner was beyond his 90 day solo privileges, so he and a CFI took it up for
some training. It came back with the alternator over charging.
A couple months ago an Ercoupe came out of a shop with the carb heat scat
tube disconnected. He was forced to make an off field landing after getting
carb ice.
The AI that signed off our Aztec had forgotten to reconnect an oil line to
the oil cooler on one engine, it puked oil all over the ramp on initial
startup.
Things like these are almost guaranteed to happen. I'm not saying that they
"should" happen, I'm just saying that they will. Mechanics are human. Ask
yours how many times he got interrupted while doing your annual, you'll be
amazed. Every interruption is a chance that something either won't get
done, or won't get finished. I'm not making excuses for them, but only
pointing out the fact that we as pilots should be aware of these things and
be extra vigilant immediately after the AI throws us the keys and says "It's
all ready to go".
Your mag problem could be something as simple as that they didn't tighten it
up firmly after timing it. It started and ran after they were done, but
then vibrated loose. Or it could have failed completely, just because it
was time for it to fail. Glad the problem surfaced on the ground.
"three-eight-hotel" wrote in message
be.
from an annual?
Todd
Old February 27th 06, 05:14 PM posted to rec.aviation.owning
On Mon, 27 Feb 2006 11:07:43 -0600, "Jim Burns"
carb ice.
startup.
all ready to go".
When I was training the aircraft C152) was given a service (50hr?)
before my long X/Country. Checked the oil and it barely touched the
bottom of the stick. Told the instructor who said can't be! Took a
look himself, then went off to find the mechanic :-)
Old February 27th 06, 05:32 PM posted to rec.aviation.owning
Extra vigilance is a good tip! I've heard the stories about crossing
the cables up, which would really make flying/landing a challenge! ;-)
I'm glad it happened on the groud too!
Todd
Old February 27th 06, 05:39 PM posted to rec.aviation.owning
I'm also glad it happened on the "ground"!
Old February 27th 06, 05:13 PM posted to rec.aviation.owning
be.
from an annual?
Todd
I like Jim's response so I won't go there. I just wanted to mention that
in this month's IFR Refresher magazine, they have an article about a
high-time pilot that was to transport a Citation jet after maintenance,
and was taking off within about 15 minutes of picking up the keys. The
weather was IMC and it appeared no pre-flight planning was done, not
much of a walk around, etc.
Right after take off, he reported a minor problem and said he needed to
return to the field, and crashed within about 2 minutes.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old February 27th 06, 05:20 PM posted to rec.aviation.owning
I have had several mechanic induced problems with my bird. Best to
climb as fast as possible and stay over landable terrain until things
are sorted out. Just the way things are.
Old February 27th 06, 05:40 PM posted to rec.aviation.owning
Three magic words to live by:
OWNER ASSISTED INSPECTIONS
Old February 28th 06, 02:16 AM posted to rec.aviation.owning
"RST Engineering" wrote in message
Post-Maintenance Test Flight (by FBO/Shop owner)
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old February 28th 06, 04:36 AM posted to rec.aviation.owning
"Matt Barrow" wrote in message
Still not near as good as owner assisted. In nearly 10 years of ownership
no one has layed a tool on my airplane without me watching like a hawk. 99%
of the work is done by me with the IA inspecting. So far no surprises and
as a plus the cost of an annual plumets.
Matt
Matthew W. Barrow
Montrose, CO
Airborne Dead Reckoning GHMyst Naval Aviation 0 January 25th 05 12:22 AM
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 10:46 PM
Annual Report Final. "Long" NW_PILOT Piloting 22 October 28th 04 07:20 PM
Another Almost Annual Christmas Poem!!! David Pincus Home Built 4 December 28th 03 12:47 PM
