x-plane
Old February 27th 06, 07:47 PM posted to rec.aviation.simulators
Default x-plane
if i buy the x-plane available in mac stores, are the global scenery
cd's compatible with the x-plane from the stores? In other words are
these one in the same?
Old February 27th 06, 08:34 PM posted to rec.aviation.simulators
Default x-plane
Hi Kevin,
Depends. The global scenery comes on 6 DVDs, not CDs (!) and usually is
sold with X-Plane 8.21 or later. So if the DVD you get at your local
store has X-Plane 8.21 or later, it will be compatible with the global
scenery. If you buy a pre-8.21 version, it will not work.
Tjark
Old February 28th 06, 06:32 AM posted to rec.aviation.simulators
Default x-plane
"Tjark Nikolai" ha scritto nel messaggio
sold with X-Plane 8.21 or later. So if the DVD you get at your local store
has X-Plane 8.21 or later, it will be compatible with the global scenery.
Not entirely correct. The X-Plane sold in stores is version 8.00. It is not
compatible with the new global scenery, but you can download the latest
upgrade (compatible with Global Scenery) to the latest X-Plane version on
www.x-plane.com
Marco
Old February 28th 06, 12:37 PM posted to rec.aviation.simulators
Default x-plane
OK, so which is the best? the one from the website or the one in
stores...which is more realistic
Old February 28th 06, 04:30 PM posted to rec.aviation.simulators
Default x-plane
"Kevin" ha scritto nel messaggio
I think there's a bit of misunderstanding here.
X-Plane is updated by the author quite often. But you get the first release
(currently, release 8.00) on the DVD.
Then, after you have installed X-Plane 8.00 from the DVD, you can simply
download the latest release (8.40 at this moment) from the website
www.x-plane.com, and update it.
Obviously, later releases have always some improvements in realism and other
feautres over previous ones.
Marco
Passenger crash-lands plane after pilot suffers heart attack R.L. Piloting 7 May 7th 05 11:17 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
