Anyone had fuel tank air vent icing up?
Old February 28th 06, 03:14 PM posted to rec.aviation.ifr
Default Anyone had fuel tank air vent icing up?
Vents are not installed in the direct impact slipstream, so
ice is not usually a problem in a well designed system.
"Peter" wrote in message
| Is there any known case of the above happening, on an
aircraft flying
| below say FL200?
| On a known-ice aircraft, the vents are normally heated.
| One reads a fair number of stories of pilots picking up a
huge amount
| of ice (inches) but not (that I have seen) of engine
failures caused
| by vacuum in the tanks.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 11:20 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 08:35 AM
