Anyone had fuel tank air vent icing up?
Old March 1st 06, 12:59 AM posted to rec.aviation.ifr
Default Anyone had fuel tank air vent icing up?
It's a problem in Bonanzas & Barons.
Heated fuel vents are an option on some Barons.
You can tell it's happening by noting the fuel gauges.
They go UP! The bladder sucks up from the tank and
deflects the outbound level sender when the vents are
blocked.
You need a plan to be on the ground.
Bill Hale BPPP instructor
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 11:20 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 08:35 AM
