Origami as a PDA
Old March 15th 06, 03:01 AM posted to rec.aviation.soaring
Default Origami as a PDA
Sometimes I find myself wishing my PDA was a tad bit bigger. With
Microsoft's 'Origami' being unveiled recently it presents a possibility
to fill that need. Obviously size and battery power is a factor in many
gliders but it would fit in my rather roomy cockpit. Question for the
computer types out there......... would this work
Old March 15th 06, 04:00 AM posted to rec.aviation.soaring
It looks like 'Origami' is Microsoft's operating system for the Ultra
Mobile PC concept, with actual platforms still to be announced. The 7"
display sounds like the right size but the 1kg target weight may be a
bit high for something mounted on a gooseneck. Perhaps less without a
battery? Let's see what the HW vendors come up with ...
Old March 15th 06, 04:09 AM posted to rec.aviation.soaring
I'm watching this too. I hope portrait mode is supported.
Old March 15th 06, 05:28 AM posted to rec.aviation.soaring
Given the screen size, a gooseneck shouldn't be neccessary, even for an
AK like me. Combined with a trackball controller, it would be quite a
system, worth carrying a bit more battery.
Ray Warshaw
1LK
Old March 15th 06, 09:50 AM posted to rec.aviation.soaring
Ray Warshaw
1LK
Maybe one of these
www.rocketmouse.com mounted on the stick or flap
handle?
Mike Borgelt
Old March 15th 06, 10:15 AM posted to rec.aviation.soaring
Ray Warshaw
1LK
Maybe one of these
handle?
Mike Borgelt
It operates with a Touchscreen same as the PDA
Old March 15th 06, 03:36 PM
TowPilot185 TowPilot185 is offline
Junior Member
First recorded activity by AviationBanter: Mar 2006
The issue will be waiting for software. The 'Origami' uses Windows XP tablet. Therefore the populare Windows Pocket PC(Windows Mobile) applications will not work without software modifcations(well you could use the PocketPC emulator but you then give up the screen real estate you where gaining). Existing desktop applications will run but are probably not optimized for the smaller screen. It is just a catch up game with us software developers when new devices are added. I'm just now updating my PocketPC apps to be 'screen aware' on the Mobile 5.0 devices all I need is another platform to modify my GUI(graphical user interface) for.
Old March 15th 06, 03:48 PM posted to rec.aviation.soaring
Hi,
I'm curious about it. Does it use a hard drive, or memory only. I wouldn't
want a hard drive in a glider.
Paul Remde
Old March 16th 06, 03:51 AM posted to rec.aviation.soaring
I'd still like to see an easy to read in the sunshine flat panel display
similar to the Garmin 1000. Then the various vendors could produce the
black boxes that would sit behind the panel and drive the really cool
software that would make those displays come to life.
Casey Lenox
KC
Phoenix
Old March 16th 06, 08:44 AM posted to rec.aviation.soaring
As an engineer I'd say "why yes, it'll work". It would be cool to
implement. I can see it would be cool to only need one device to run
in-flight and flight analysis applications, but then given the amount of
stuff we lug around to support our flying, the extra room for a PDA and
a laptop is not too much of an issue.
As a "Product Development Specialist" I'm interested to know what info
you'll want on your bigger display and what (additional?) functions
you'd like to see? What are the market requirements & how much is it
worth? What is the "killer app" that means we'll improve the
performance or safety of our flying and possibly make squillions from
it? Best to keep that to yourself perhaps
I ask this because I'm still new to gliding (~50hrs) and choose to log
flights for interest sake only using a Palm PDA & GPS mouse (because
that's what I had before I started gliding). I don't use it for Tasks
or navigation but it would be nice to be able to select a radio nav-aid
and have radial and distance displayed for when I'm talking to ATC.
I'll be using a Volkslogger when I need an IGC approved FR. And I'll
still need to take: charts, food & drink, Flarm,...
At 9"x5"x1" I dunno where a UMPC would fit around the cockpit of the
G103 and still be visible? I use a knee board to hold my PDA. Maybe if
I had a Stemme S10, space wouldn't be an issue?
Since I wasn't fortunate enough to be at Cebit last week I'll speculate:
- UMPCs have transflective displays which may be difficult to see in
bright sunlight unless they have some good enhancement films.
- flame wars will abound given a likely 18V or 20V external DC supply
(usually its an AC/DC adapter just like a Notebook PC).
- the Hard Drives may have "drop sensors" to safe-guard the drive heads.
I don't know how this "interruption" affects the OS: will this be an
issue in a lumpy wave rotor?
Here's one UMPC example:
http://www.engadget.com/2006/03/10/t...sk-v-700-umpc/
Disclaimer: I'm on the hardware design team of a Windows Mobile 5 PDA.
Cheers
Neil
