Loading TP to Garmin 396
Old March 22nd 06, 05:00 PM posted to rec.aviation.soaring
Default Loading TP to Garmin 396
Does anyone have any experience of loading Turnpoint Exchange turnpoint
files to the Garmin 396? If so what utility and what file format did
you use?
My previous experience is with a Garmin 95XL using the Garmin PCX5
software.
thanks
Andy
Old March 22nd 06, 06:57 PM posted to rec.aviation.soaring
..wpt is for garmin is it not ?
http://soaring.aerobatics.ws/TP/ASA/files.html
Old March 22nd 06, 11:04 PM posted to rec.aviation.soaring
you use?
software.
thanks
Andy
..wpt. I've used Gartrip for many years. www.gartrip.de Works with
Garmin and Magellan receivers.
Chip Fitzpatrick
Old March 23rd 06, 02:33 AM posted to rec.aviation.soaring
http://www.garmin.com/support/collec...t=010-00425-00
Old April 8th 06, 04:34 PM posted to rec.aviation.soaring
you use?
This all turned out to be a non-problem. I have found that the Garmin
provided utility Mapsource will open the old PCX5 format waypoint
files. So the 396 can be loaded with garmin pcx5 files that are already
available on tp exch.
Andy
Old April 9th 06, 03:21 PM posted to rec.aviation.soaring
I suspect there are very few 396's being used for soaring but was
browsing Garmin for an update to Mapsource and found this
"Changes made from version 6.7 to 6.8.0:
* This will be the last version of MapSource to support
reading/importing PCX5 files. For future compatibility, please migrate
your data to the GPX format."
I have version 6.5. Current version is 6.10.2
Back to G7toWin.
Andy
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
