Could Sea Harrier FRS1 safely land vertically with two unused Sea
Eagles attached in hot weather condition? |
![]() "KDR" wrote in message oups.com... Could Sea Harrier FRS1 safely land vertically with two unused Sea Eagles attached in hot weather condition? Your question evokes the immediate response ... insufficient data. Read the ODM ... (Operating Data Manuals) The manual consisted of lots of charts and a 'data point' can be extracted by 'entering' one chart with a condition (say weight) against 'day' (ISA + n deg) then perhaps taking that datapoint onto another chart reading off height (above mean sea level) which might give you an answer to your question. Of hand; - two minutes after take-off from Nairobi in mid-summer... ? whereas after a two hour sortie from the Falklands in mid-winter ... ? Context, as they say, is everything. -- Brian |
![]() Brian Sharrock wrote: "KDR" wrote in message oups.com... Could Sea Harrier FRS1 safely land vertically with two unused Sea Eagles attached in hot weather condition? Your question evokes the immediate response ... insufficient data. Read the ODM ... (Operating Data Manuals) The manual consisted of lots of charts and a 'data point' can be extracted by 'entering' one chart with a condition (say weight) against 'day' (ISA + n deg) then perhaps taking that datapoint onto another chart reading off height (above mean sea level) which might give you an answer to your question. Of hand; - two minutes after take-off from Nairobi in mid-summer... ? whereas after a two hour sortie from the Falklands in mid-winter ... ? Context, as they say, is everything. -- Brian OK, could Sea Harrier FRS1 safely land vertically on the Invincible class carrier in the South China Sea in mid-summer with two unused Sea Eagles after a two-hour mission? Was there any case the FRS1 had to jettison unused Sea Eagles before landing on the carrier? |
![]() "KDR" wrote in message oups.com... Brian Sharrock wrote: "KDR" wrote in message oups.com... Could Sea Harrier FRS1 safely land vertically with two unused Sea Eagles attached in hot weather condition? Your question evokes the immediate response ... insufficient data. Read the ODM ... (Operating Data Manuals) The manual consisted of lots of charts and a 'data point' can be extracted by 'entering' one chart with a condition (say weight) against 'day' (ISA + n deg) then perhaps taking that datapoint onto another chart reading off height (above mean sea level) which might give you an answer to your question. Of hand; - two minutes after take-off from Nairobi in mid-summer... ? whereas after a two hour sortie from the Falklands in mid-winter ... ? Context, as they say, is everything. -- Brian OK, could Sea Harrier FRS1 safely land vertically on the Invincible class carrier in the South China Sea in mid-summer with two unused Sea Eagles after a two-hour mission? Was there any case the FRS1 had to jettison unused Sea Eagles before landing on the carrier? Sorry, but you would have to read the ODM. If you don't have access to the data you probably aren't authorised to have it. [its tough, but it's life] ..If you have a legitimate need-to-know; try posing the question to the manufacturer's marketing department. -- Brian |
![]() KDR wrote: Brian Sharrock wrote: "KDR" wrote in message oups.com... Could Sea Harrier FRS1 safely land vertically with two unused Sea Eagles attached in hot weather condition? Your question evokes the immediate response ... insufficient data. Read the ODM ... (Operating Data Manuals) The manual consisted of lots of charts and a 'data point' can be extracted by 'entering' one chart with a condition (say weight) against 'day' (ISA + n deg) then perhaps taking that datapoint onto another chart reading off height (above mean sea level) which might give you an answer to your question. Of hand; - two minutes after take-off from Nairobi in mid-summer... ? whereas after a two hour sortie from the Falklands in mid-winter ... ? Context, as they say, is everything. -- Brian OK, could Sea Harrier FRS1 safely land vertically on the Invincible class carrier in the South China Sea in mid-summer with two unused Sea Eagles after a two-hour mission? Was there any case the FRS1 had to jettison unused Sea Eagles before landing on the carrier? I would imagine that after 2 hours the fuel load would be so reduced that the weight of the missiles wouldn't come into the equation. Dumping missiles would get one on jankers quicksmart |
In rec.aviation.military KDR wrote:
snip OK, could Sea Harrier FRS1 safely land vertically on the Invincible class carrier in the South China Sea in mid-summer with two unused Sea Eagles after a two-hour mission? Was there any case the FRS1 had to jettison unused Sea Eagles before landing on the carrier? The trivial way would be to look up the weight of a Sea Eagle. 600Kg per. So, 1200Kg. The first site I found gave 2295Kg of fuel for a model of the harrier. So, if it can land fully fueled, but without the eagles, then it can land with about half and them. Assuming no COG/... issues. |
Sea Eagles? Probably not.
Sea Harriers are known for having power difficulties in warm weather and Sea Eagles are heavy. There were a number of situations in Iraq where Sea Harriers were unable to participate because of the weather which is why they are being retired and replaced by RAF GR.xs. |
Airyx wrote:
Sea Eagles? Probably not. Sea Harriers are known for having power difficulties in warm weather and Sea Eagles are heavy. There were a number of situations in Iraq where Sea Harriers were unable to participate because of the weather which is why they are being retired and replaced by RAF GR.xs. Yes Sea Harrier FA2 does have that problem but what I want to know about is FRS1. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
