Winpilot and OLC
Old March 26th 06, 08:57 AM posted to rec.aviation.soaring
Default Winpilot and OLC
Hi
I wonder if it is possible to upload a PDA/Winpilot IGC file to the OLC?
I know the log is not secure but will be accepted for scoring? Winpilot
is definitely not on the list of OLC approved software. If it is not
possible, does anyone know why Winpilot has been excluded?
Paul
Old March 26th 06, 02:55 PM posted to rec.aviation.soaring
I have used it successfully, if you use the igc file rather than the
cai file
Gary
Old March 26th 06, 03:01 PM posted to rec.aviation.soaring
Gary,
I think you mean you were uploading the file from your cambridge logger
not from WinPilot's built-in logger.
To answer Paul's question though, WinPilot is still on the OLC Approved
Software list (http://www.onlinecontest.org/validate.php) though many
others are. I believe the only reason for this is because Jerry hasn't
added a security signature ("G" Records) to his IGC files and then
produced a corresponding "VALI" program to validate the IGC files. If
he did this and sent it to the OLC, they would then be able to validate
WinPilot log files. They would then get the blue "V" for validation
which is just fine. This is what I did with SoarPilot a couple of
years ago and it SP's log files validate just fine.
Later!
-Mark
Old March 26th 06, 10:54 PM posted to rec.aviation.soaring
No, actually, when I upload from my Cambridge logger, through the
winpilot I get two files, IGC and CAI, using the IGC files with OLC I
have no problem.
Gary
