The F14 vs what we are doing now
Old March 26th 06, 08:17 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Default The F14 vs what we are doing now
Shmaryahu b. Chanoch wrote:
The History Channel recently had a piece on the F14. I did not realize that
plane came out of the F111 program. Nor that it could track 24 enemy targets,
engaging up to 6 at a time (and at long range).
Cynically wouldn't it be more correct to say that the US Navy would
have done anything to avoid buying the F-111B? They essentially
optioned it to death and then provide their own custom designed
replacement.
Scott Peterson
At least I have a positive attitude
about my destructive habits.
(147/689)
Old March 26th 06, 04:10 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Scott Peterson wrote:
:Shmaryahu b. Chanoch wrote:
:The History Channel recently had a piece on the F14. I did not realize that
:plane came out of the F111 program. Nor that it could track 24 enemy targets,
:engaging up to 6 at a time (and at long range).
:Cynically wouldn't it be more correct to say that the US Navy would
:have done anything to avoid buying the F-111B? They essentially
:replacement.
No, it wouldn't. Compare the two airplanes.
What 'option' did the F-111B include that wasn't a mission for the
F-14?
"Millions for defense, but not one cent for tribute."
-- Charles Pinckney
Old March 26th 06, 09:40 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
On Sun, 26 Mar 2006 15:10:36 GMT, Fred J. McCall
:replacement.
F-14?
The F-111B, as I understand it, never weighed less than 78,000 lbs,
whereas the USN insisted that the ships couldn't handle anything
greater than 55,000 lbs. It's interesting to note that the F-14
weighs about 40,000 lbs empty, and the F-18A less. Considering that
the F14 for a while did used the same engines as the F-111, it's easy
to see the complaint that the F-111B was grossly underpowered as
justified.
Old March 27th 06, 05:12 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
In article , Pete Granzeau
Where can one find definitive weights for these aircraft? And also
definitive weights for the "do not exceed" limits when the 111B was being
killed and the F-14 was being developed?
I've got a pretty good reference library with a number of books on the F-14,
but I've never found good comparisons of the weights issue. I have heard
that ultimately the F-14 exceeded the weight that was originally established
for the 111B. And I don't know how much the 111B's weight was reduced to.
There is a story that the F-14 broke the weight that the 111B was supposed
to meet and that this was "allowed" because the Navy wanted the F-14 but did
not want the F-111B. But I don't know if that is true. And it is also the
case that if the F-111B was still too fat, it was going to be way too heavy
for carrier acceptability whereas the F-14 was acceptable. But I cannot
find the numbers.
D
