A lot of Rutan planes and derivatives call for polyurethane (in the
fuselage). My understanding is that starting around 1990, builders have used urethane instead of polyurethane (in Long EZs, etc.). Has this scenario taken place with Quickie Q1 s... ? Since most Q1s were built before 1995, would it be safe to say almost all Q1s have polyurethane...? |
On 27 Mar 2006 12:15:36 -0800, "
wrote: A lot of Rutan planes and derivatives call for polyurethane (in the fuselage). My understanding is that starting around 1990, builders have used urethane instead of polyurethane (in Long EZs, etc.). Has this scenario taken place with Quickie Q1 s... ? Since most Q1s were built before 1995, would it be safe to say almost all Q1s have polyurethane...? To my knowledge all Quckie Q1s were wire cut from Polystyrene foam billets. Urethane foam cannot be wire cut since it emits a poisonous gas. |
![]() wrote in message ups.com... A lot of Rutan planes and derivatives call for polyurethane (in the fuselage). My understanding is that starting around 1990, builders have used urethane instead of polyurethane (in Long EZs, etc.). Has this scenario taken place with Quickie Q1 s... ? Since most Q1s were built before 1995, would it be safe to say almost all Q1s have polyurethane...? The canard, wing, vertical tail, and all controls are built using polystyrene (Styrofoam). The fuselage is urethane foam. The turtle deck does use some PVC foam there but that is the extent of it. The only changes have been where the materials come from not how much/where it is being used in construction. The Styrofoam is hotwired and the urethanfoam is sanded (if you can call it that) unless you follow a few surfboard pages and hotwire it. The later explains why surfers are dieing out. The pvc is bent with a heat gun. The best and up to date source of information is going to be QBA http://www.quickiebuilders.org/ and the Q-list on yahoogroups. http://groups.yahoo.com/group/Q-LIST/ Nemo |
Later planes - Long EZ's, etc - were largely built with PVC fuselages,
and Styrofoam flying surfaces. Urethane foam and polyurethane foam are the same thing. |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
want to trade 601 plans for 701 plans | [email protected] | Home Built | 0 | January 27th 05 07:50 PM |
Unused plans question | Doc Font | Home Built | 0 | December 8th 04 09:16 PM |
blue foam & cutting it | Richard Riley | Home Built | 6 | November 24th 03 01:53 PM |
