I'm looking into buying an 18m Diamant. There doesn't appear to be much
info about this particular model on the net other than the BGA's tech sheet and a few odd references. I have no issue with it being flapped etc. I wondered if anyone had experience with the 18 metre Diamant or new of a url for more info. I'm told Jane's World Sailplanes has some good info but other than that nada. here's hoping Phil |
Phil, I havent flown one myself but you may find some information on: www.sailplanedirectory.com Hope this helps, JR At 16:48 28 March 2006, Phil Collin wrote: I'm looking into buying an 18m Diamant. There doesn't appear to be much info about this particular model on the net other than the BGA's tech sheet and a few odd references. I have no issue with it being flapped etc. I wondered if anyone had experience with the 18 metre Diamant or new of a url for more info. I'm told Jane's World Sailplanes has some good info but other than that nada. here's hoping Phil |
I had one a long time ago. See this thread on gliderforum:
http://www.gliderforum.com/thread-view.asp?threadid=729 John Galloway At 18:12 28 March 2006, Jono Richards wrote: Phil, I havent flown one myself but you may find some information on: www.sailplanedirectory.com Hope this helps, JR At 16:48 28 March 2006, Phil Collin wrote: I'm looking into buying an 18m Diamant. There doesn't appear to be much info about this particular model on the net other than the BGA's tech sheet and a few odd references. I have no issue with it being flapped etc. I wondered if anyone had experience with the 18 metre Diamant or new of a url for more info. I'm told Jane's World Sailplanes has some good info but other than that nada. here's hoping Phil |
Contact Ray Poquette. He loves the Diamant 18.
Ray is "Thermo-Tec", and his number is in the classified section of "Soaring". Mike phil collin wrote: I'm looking into buying an 18m Diamant. There doesn't appear to be much info about this particular model on the net other than the BGA's tech sheet and a few odd references. I have no issue with it being flapped etc. I wondered if anyone had experience with the 18 metre Diamant or new of a url for more info. I'm told Jane's World Sailplanes has some good info but other than that nada. here's hoping Phil |
I had a Diamant 18 from 1974 - 1983. I had about 750 and some odd hours
in it. The info from Art on the Glider Forum is good. The 18 had an AD on the spar stubs that limited your VNE until it was accomplished. Most of the ones around had already had the earlier ADs on the flap counterweights and the rudder damper done already by the factory which had a representative travel around and fix them (Fred Jiran). I flew it for a long time and sold it without ever complying with the spar stub AD, because in normal flying, it was rarely necessary to go that fast anyhow. The factory, FFA from Switzerland was still supporting it and provided a kit to accomplish the spar stub AD. It's a real floater for a glass ship. It has a very good L/D, but it comes at a relatively slow speed. It looks a lot like an ASW-12 and has a similar max L/D, but the whole performance curve is shifted over to the left, so everything happens about 10mph or more slower than the ASW-12. But compared to the 12, it's a much easier and safer ship for ordinary mortals to fly. It has a lot of washout in the wing, which I think is one of the reasons the stall/spin behavior is very good, but this hurts it's high speed performance. This is both good and bad. I think it could still stay up on weak days better than any ship I can think of, even today, except maybe the LightHawk. It would make an excellent contender in the "micro-lift" arena, even today. It has a very slow stall speed and landing speed. You can get it down below 30 knots when thermalling. The real expert on Diamants is Dan Pierson. He used to fly his with as much or more than 70 gallons of water. This would put him even or even better than the ASW-12 and tantalizingly close to some of the big open ships like the Nimbus 2 at the time. Dan still has his 18 and has extended the wing to 19 meters. He had taken up "open cockpit" Diamant flying with the aft part of the canopy removed the last time I talked to him. I don't think you would want to land it gear up, as the fuselage is actually a foam sandwich construction and the amount of glass over the foam is pretty thin and would not take much abrasion. Once you got into the foam, your hind end would be scraping the surface in very short order, I think. The rather small size, of the landing gear definitely comes into play when you fly it with that much water. It was a real big risk to take off on that gear with that kind of weight. You could only do it at carefully checked runways with no chance of any holes or bumps, and even then, it was a big risk. With no water ballast, the gear is adequate, although on the small side - I think it used the same size hub and tire as a Libelle which was a much smaller ship. I never flew mine with more than 45 gallons. I considered the 25 gallon difference between me and Dan Pierson as my safety factor, since no formal structural analysis of flying with that much water had been done :-) The wings are big and one piece, but not really all THAT heavy, I mean, esp. compared to a Nimbus 2 or ASW-17 inner panel. The main pin on the spar stub had to be lined up just right with the bearing on the root rib of the other wing, or it just would not go together, and it was a rather bluntly rounded pin, so it was very difficult to visually tell if it was lined up right. I found that it was easier to do it by feel out on the wingtip. There was a certain "sweet spot" and you could with practice find that pretty easily. When it was lined up in the sweet spot, it would just fall together very easily. But if you were not in the sweet spot, no amount of force would help. It had a rigging lever similar to a Libelle, but that was totally useless. As far as flying qualities, the flaps are very nice and very effective for decreasing landing speed and help give you a better view over the nose (your feet) when landing. The dive brakes are also very effective and combined with the landing flap position and the excellent view, and the very low stall speed, make it a very nice ship to land. The reclining position is very comfortable once you get used to it. It is very narrow in the cockpit, but pretty long, that's pretty obvious just from looking at a picture of the ship. The rudder is very heavy on the 18. That is really because it has a very large area, and is driven by a pushrod system and the lever arm that drives the pushrod in the nose is only a few inches long, so the amount of force required from your feet can be quite high just due to the mechanics of the short lever arm. The all flying tail is quite sensitive, but not any more so than a Nimbus 2 or a Std. Cirrus. The ailerons can have a lot of friction, and the forces are high compared to some other designs. The ailerons use these drivers that have ball bearings with races at 45 deg angles to translate the lateral motion of the pushrods to an up and down motion. These can get dry and were usually not accessable because the fittings they attach to the wing by had been filled over with filler. But you can remove the filler and take them appart to clean and grease them. I used to try to spray a light weight lubricant on the bearings but then you get more dirt in there and you can't get in there and clean it out without taking them apart. Alex Caldwell Tulare,CA phil collin wrote: I'm looking into buying an 18m Diamant. There doesn't appear to be much info about this particular model on the net other than the BGA's tech sheet and a few odd references. I have no issue with it being flapped etc. I wondered if anyone had experience with the 18 metre Diamant or new of a url for more info. I'm told Jane's World Sailplanes has some good info but other than that nada. here's hoping Phil |
My first glider was a Diamant 16.5M, extended to 17.2M. Except for being a bit sensitive in pitch, It was easy to fly, docile and climbed great. The pilot seating is very reclined and this required some getting used to. Rigging can be challenging...bring friends. Don't fly it with white shoes though because the highly curved canopy magnifing the reflection and the movement of your feet can be very distracting. Paul phil collin wrote: I'm looking into buying an 18m Diamant. There doesn't appear to be much info about this particular model on the net other than the BGA's tech sheet and a few odd references. I have no issue with it being flapped etc. I wondered if anyone had experience with the 18 metre Diamant or new of a url for more info. I'm told Jane's World Sailplanes has some good info but other than that nada. here's hoping Phil |
I owned a share of a Diamant 18 from 1974 to 1979.
It was my first glass glider and I found it relatively easy to fly with few vices. There was a mod to the all moving elevator that some UK Diamants had -- ours did not. The mod was a small extension to the middle aft part of the elevator and was intended to increase the pitch stability. Without this mod the pitch stability is rather poor and in fact stick forces REVERSE at high speeds. To make this clear, the faster you fly, the more you need to hold the stick back! Very weird. If you let go the glider would (presumably) go into an immediate bunt. However we never bothered to have the mod done and I guess that shows that we did not have any qualms about the handling (or were we young and foolish?). As others have said the brakes are excellent and extend from the top and bottom wing surfaces. The canopy opening mechanism and cockpit shape are very unconventional but caused us no problem. A previous owner did suffer a partial opening of the canopy in flight and flew the rest of the flight one handed while holding the canopy on with the other! I don't remember any problems with the rectractable U/C. However I did manage to bend the axle in a firm landing. So I would say that the U/C is strong enough. Ours was landed wheels up at least twice. Once on a tarmac runway with a cine camera strapped to the underside. This caused a fair amount of damage. The second time I was the pilot and got away without any damage on a soft hay field. I don't think I have flown a better glider for weak wave. However a modern standard class glider will outperform the Diamant in thermal cross-country tasks. |
| Thread Tools | |
| Display Modes | |
| Diamant 16.5 Part Out... | [email protected] | Soaring | 3 | October 7th 18 09:36 PM |
| gliders with Jet engines | Eric Greenwell | Soaring | 9 | September 26th 03 07:03 PM |
