Can IFR-certified GPS be used to substitute for NDBs in Canada when
navigating an airway? I'm a US-certificated pilot flying a US-registered plane. I'd like to take advantage of lower MEAs in western Canada provided by airways. Many of the airways appear to be between NDBs. If my ADF is known inop (or my plane doesn't have an ADF), can I use the panel-mount Garmin 430 as a substitute? |
Yes, except for approaches that do not have a GPS overlay and for
missed approch procedures that have an NDB in them (the latter doesn't make to me IMHO). Gerd ATPL From the TC AIM (http://www.tc.gc.ca/CivilAviation/pu...14371/menu.htm): 3.16.9 Use of GNSS in Lieu of Ground-based Aids Subject to any overriding conditions or limitations in the aircraft flight manual (AFM) or AFM Supplement, GNSS may be used to identify all fixes defined by DME, VOR, VOR/DME and NDB, including fixes that are part of any instrument approach procedure, to navigate to and from these fixes along specific tracks, including arcs, and to report distances along airways or tracks for separation purposes. This can be done as long as there is no integrity alert, and provided that all fixes that are part of a terminal instrument procedure (arrival, departure, or approach) are named, charted and retrieved from a current navigation database. GNSS may be used to identify fixes defined by ground-based aids, even if they are temporarily out of service. For example, if the DME associated with an ILS/DME approach is unserviceable, traditional aircraft would be denied the approach; however, under these rules, the pilot of a GNSS-equipped aircraft may request and fly the approach. Note that for NDB or VOR approaches that are not part of the GPS overlay program described in Section 3.16.5.2.2, pilots shall use ADF or VOR as the primary source for final approach track guidance. For these approaches, and for approaches based on a localizer (LOC) for lateral guidance, pilots shall not use GNSS as the primary source for missed approach guidance when the missed approach procedure requires flying a published track to or from an NDB or VOR.Where ATS requests a position based on a distance from a DME facility for separation purposes, the pilot should report GPS distance from the same DME facility, stating the distance in "miles" and the facility name (e.g. "30 miles from Sumspot VOR"). This phraseology is used for all RNAV systems. When reporting DME distance, the pilot includes "DME" in the report (e.g. "30 DME from Sumspot VOR"). This enables ATS to allow for the DME slant range. Note that under this approval, there is no requirement to carry the avionics normally used to identify fixes defined by ground-based aids, but other considerations may apply. This topic is discussed in Section 3.16.10. |
| Thread Tools | |
| Display Modes | |
| [Fwd: [RAA-N] RAA events Goderich] Ontario Canada August 25th 26th27th | Robert Schieck | Home Built | 0 | August 23rd 05 03:08 PM |
| Trip Report - Canada (long) | Andrew Sarangan | Piloting | 8 | August 26th 04 04:34 AM |
| Could Canada Build | Charles Talleyrand | Military Aviation | 22 | July 11th 04 11:05 PM |
| French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 07:48 PM |
| Reflections on first trip to Canada from US | Mike & Janet Larke | Instrument Flight Rules | 1 | August 9th 03 01:57 AM |
