Knowing what Part 21 Type Certificate you have matters because that is how
the other Parts of CFR 14 are tied together. Say one doesn't know they have an experimental type certificate, then how can they know that Part 23 and 43 are not applicable? Additional regulatory requirements are made for Normal Catagory airplanes that may be an undue burden for someone building their own airplane, that they are intending to operate themselves. Even if later some of these are sold, it is my estimation that a homebuilt with 200 hours on it is an order of magnitude safer than a green one. |
"Tarver Engineering" wrote in message ... Knowing what Part 21 Type Certificate you have matters because that is how the other Parts of CFR 14 are tied together. Say one doesn't know they have an experimental type certificate, then how can they know that Part 23 and 43 are not applicable? There's no such thing as an experimental type certificate. There are experimental AIRWORTHINESS certificates. The entire discussion of experimental certificates occurs in 21.191. It is a term that applies to airworthiness certificates. There is no type certificate. |
"Ron Natalie" wrote in message . .. "Tarver Engineering" wrote in message ... Knowing what Part 21 Type Certificate you have matters because that is how the other Parts of CFR 14 are tied together. Say one doesn't know they have an experimental type certificate, then how can they know that Part 23 and 43 are not applicable? There's no such thing as an experimental type certificate. There are experimental AIRWORTHINESS certificates. The entire discussion of experimental certificates occurs in 21.191. It is a term that applies to airworthiness certificates. There is no type certificate. There is no production certificate for an experimental, but it is a tpye of airplne in Part 21 and Part 43. |
"Tarver Engineering" wrote in message ... There is no production certificate for an experimental, but it is a tpye of airplne in Part 21 and Part 43. It is a type, but there is no "TYPE CERTIFICATE." You are correct that without a type certificate, there is also no production certificate. |
"Ron Natalie" wrote in message . .. "Tarver Engineering" wrote in message ... There is no production certificate for an experimental, but it is a tpye of airplne in Part 21 and Part 43. It is a type, but there is no "TYPE CERTIFICATE." You are correct that without a type certificate, there is also no production certificate. Now Ron, the reason the 337 is not applicabl is because the homebuilt is an experimental, as is written explicitly in Part 43. Or do you have an additional "red queen" finding from FAA Chief counsel? The 100 hour inspection exception you quoted the FAA chief counsel as finding is a change to engineering, on no basis; just like Kelly got the MIDO to chang the lubrication scedule for DC-9s on "no basis". Perhaps the FAA chief counsel would do well to review some of these "good buddy" word games. I know engineers that say, "just because I said that before does not mean I say that now". The rest of FAA gave up most of that "good buddy" type thinking with the FY97 budget. |
WARNING! PLONK MODE IMMINENT!
Mssrs. Tarver and Natalie: I've had enough of this personal diatribe. Please, take it off the newsgroup and onto your personal emails. Yes, I can execute the delete button but my finger is getting tired. |
| Thread Tools | |
| Display Modes | |
| homebuilt safety | anonymous coward | Home Built | 96 | June 3rd 04 05:34 AM |
| What is best "JB Weld" type epoxy putty? | [email protected] | Home Built | 4 | March 8th 04 08:45 AM |
| WTB VW Type I Reduction Drive | Alan | Home Built | 0 | January 2nd 04 05:14 AM |
| Type of wing carrythrough? | Toks Desalu | Home Built | 0 | October 30th 03 09:35 PM |
| These are the coolest certificates | Frederick Wilson | Home Built | 2 | September 28th 03 05:36 PM |
