Has this one been around the block a few times?
It was an interesting read. http://www.pureenergysystems.com/new...00069_Acetone/ Acetone In Fuel Said to Increase Mileage "Readily-available chemical added to gas tank in small proportion improves the fuel's ability to vaporize completely by reducing the surface tension that inhibits vaporization of some fuel droplets." http://toyotaownersclub.com/forums/i...howtopic=44575 Chat room chat about acetone - mostly diesel cars. This is for diesels mostly ...and mogas WITHOUT alcohol in it. A few ounces/10 gallons is all you use. Montblack |
30% increase of gas mileage? That's some outrageous claims.
"Montblack" wrote in message
... Has this one been around the block a few times? It was an interesting read. http://www.pureenergysystems.com/new...00069_Acetone/ Acetone In Fuel Said to Increase Mileage "Readily-available chemical added to gas tank in small proportion improves the fuel's ability to vaporize completely by reducing the surface tension that inhibits vaporization of some fuel droplets." http://toyotaownersclub.com/forums/i...howtopic=44575 Chat room chat about acetone - mostly diesel cars. This is for diesels mostly ...and mogas WITHOUT alcohol in it. A few ounces/10 gallons is all you use. In gasoline engines, unburned Hydrocarbons amount to about 1% of the total fuel, and most of those come from crevices such as the gap around the piston above the top ring, and around the spark plug - the compression and pressure rise pushes the mixture into these spots where the flame front is quenched. The next largest source is a thin layer that is quenched at the cylinder walls from the heat loss to the metal. I don't have the numbers handy for diesels, but I'm reasonably confidant that the percentage isn't a lot different even if the sources are different (over rich areas in the fuel spray generate soot due to inadequate air and some of the mixture around the fringe of the spray is too lean to burn). The fact of the matter is that the moon landings are fake, the alien autopsies are real, and the thousands of engineers that work for all the auto companies all around the world (that look at fuel sprays and combustions with lasers, high speed cameras, optically transparent engines of all types, computer modeling, etc.) are completely unaware of potential fuel consumption improvements like this one. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Montblack wrote:
Has this one been around the block a few times? Regardless, I wouldn't put that or any other chemical in a fuel system not specifically designed for it. -- __________________________________________________ _______________ Like free stuff? www.givie.com |
Yep. I would not be too keen on putting very much ketones into any fuel
system that has any plastic or rubber parts anywhere in contact with the fuel. |
In article , TheSeaHawkatwowwayd0tcom
says... I don't have the numbers handy for diesels, but I'm reasonably confidant that the percentage isn't a lot different even if the sources are different (over rich areas in the fuel spray generate soot due to inadequate air and some of the mixture around the fringe of the spray is too lean to burn). The fact of the matter is that the moon landings are fake, the alien autopsies are real, and the thousands of engineers that work for all the auto companies all around the world (that look at fuel sprays and combustions with lasers, high speed cameras, optically transparent engines of all types, computer modeling, etc.) are completely unaware of potential fuel consumption improvements like this one. That's right! ;-) And advanced concepts like vapor pressure (volatility) are just way out of their league! Of course, the vapor pressure of the fuel varies considerably with ambient temperature, and the designers must optimize all of the fuel delivery and mixing parameters for an average. Then the fuel product delivered is varied throughout the year in places where wide seasonal variations could otherwise make conditions far from the design datum. Perhaps it could happen that someone in one such place has been able to achieve a slight improvement with a home brew additive - he'll have to weigh the savings against the increased maintenance costs in early replacement of all polymerized parts of his fuel delivery system. GF |
On Thu, 13 Apr 2006 22:05:52 -0400, "JohnH"
wrote: Montblack wrote: Has this one been around the block a few times? Regardless, I wouldn't put that or any other chemical in a fuel system not specifically designed for it. But if you pu tit in your fiberglass airplane fule tanks they will start getting larger, well at least between the ribs on the bottom. OTOH you'll be able to see the ribs on top too. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Gee, if a little acetone will do this much good just think about what
putting MEK into the tank will do for your mileage... denny, aka P.T. Barnum |
On 14 Apr 2006 04:18:55 -0700, "Denny" wrote:
Gee, if a little acetone will do this much good just think about what putting MEK into the tank will do for your mileage... Hey! I have a bunch of MEKP. It's *almost* the same thing except for a few extra oxygen atoms. I'm afraid the IO-470N in the Deb has too much compression so we might have to use Fat Albert with those lower compression engines.:-)) Kinda reminds me of a guy who ran up the engines on his Queen Air up at Terry's. They have manually adjustable waste gates on the turbos. Blew one of the jugs right off the engine. As I recall the case wasn't left in that great a shape either. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com denny, aka P.T. Barnum |
| Thread Tools | |
| Display Modes | |
| Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 08:04 PM |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| "Tanks on both" checklist item | Koopas Ly | Piloting | 46 | December 12th 03 04:42 PM |
| Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 05:09 PM |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
