Updated pictures he
http://s66.photobucket.com/albums/h2...ardrider/Ribs/ Right wing is done. Left wing top rivet work is done and bottom rivet work is in progress. Should be airworthy before the end of next week. GNS-430 is back from Garmin (had to comply with an AD and get a hardware & software update done). Cheapest part installed on the plane to date: $6 luggage door strap from Ground Tech. Has absolutely nothing to do with the rib repair...but it's nice to know that not *everything* costs an arm and a leg. Well, ok, nearly everything...but at least not a luggage door strap. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
Ground Tech. Has absolutely nothing to do with the rib repair...but it's nice to know that not *everything* costs an arm and a leg. Well, ok, nearly everything...but at least not a luggage door strap. You bought a luggage door strap? Mary cut the little latchy thing out of our old grody one, inserted said latchy thing into a piece of rip-stop nylon strap she had laying around her sewing room, and I screwed it the other end into place. Cost: Priceless! :-) (Did you see they now make a gas piston opener for our luggage door?) -- Jay Honeck Iowa City, iA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
How many AMU's is all this going to set you back Jack? Sounds salty....
I am crossing my fingers that the 9 AMU annual of last year dosn repeat itself next month for annual # 2 (please no flames about the difference between an annual as most of us refer to it as, and the technical annual inspection). Jon Kraus '79 201 4443H @ TYQ Jack Allison wrote: Updated pictures he http://s66.photobucket.com/albums/h2...ardrider/Ribs/ Right wing is done. Left wing top rivet work is done and bottom rivet work is in progress. Should be airworthy before the end of next week. GNS-430 is back from Garmin (had to comply with an AD and get a hardware & software update done). Cheapest part installed on the plane to date: $6 luggage door strap from Ground Tech. Has absolutely nothing to do with the rib repair...but it's nice to know that not *everything* costs an arm and a leg. Well, ok, nearly everything...but at least not a luggage door strap. |
On Sat, 29 Apr 2006 15:34:26 -0700, Jack Allison wrote:
Updated pictures he http://s66.photobucket.com/albums/h2...ardrider/Ribs/ Dayem Jack, This hurts just looking at the pictures! Hope you get 'er up and flying soon! Will there be rigging adjustments need to be done after your first beta flight? Allen |
Keep puttering on the "little things", it'll keep your mind off the big
things. They should have at least had the heart to send a free box of Kleenex when they sold you those ribs. Maximum royal suckage. Glad it's coming together. Jim |
Jay Honeck wrote:
Cheapest part installed on the plane to date: $6 luggage door strap from Ground Tech. Has absolutely nothing to do with the rib repair...but it's nice to know that not *everything* costs an arm and a leg. Well, ok, nearly everything...but at least not a luggage door strap. You bought a luggage door strap? Yes, I did. $6 from Ground Tech. Cheap cheap! Well, ok, not as cheap as Mary and her sewing expertise but when you factor in that it took me a whopping 10 minutes of my time (5 noodling around their website, 5 more on the phone with them)...it's pretty hard to beat. Mary cut the little latchy thing out of our old grody one, inserted said latchy thing into a piece of rip-stop nylon strap she had laying around her sewing room, and I screwed it the other end into place. Cost: Priceless! :-) But is it a PMA part? :-) (Did you see they now make a gas piston opener for our luggage door?) Yes. Very cool but, IMHO, very over priced. IIRC, something like .179 AMU. Cool but I'll take the $6 strap -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
Jon Kraus wrote:
How many AMU's is all this going to set you back Jack? Estimate was 50-70 hours labor at $70/hr. Parts were 1.2 AMUs. Do the math and it's just south of 5 AMUs on the low side. We don't like to think about the high side. The labor estimate was purposely high as the shop doesn't like to overrun. One nice thing is that they didn't track the number of hours on the right wing as they had extra learning curve time to deal with. They're going to take the number of hours for the left wing (which is taking much less time) and double it. I'll be sure to post the final AMU amount. Kleenex gladly accepted. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
A Lieberman wrote:
On Sat, 29 Apr 2006 15:34:26 -0700, Jack Allison wrote: Updated pictures he http://s66.photobucket.com/albums/h2...ardrider/Ribs/ Dayem Jack, This hurts just looking at the pictures! Yep, it's pretty sad to see how many rivets needed to be drilled out. Felt like a kit builder's nightmare. Hope you get 'er up and flying soon! Will there be rigging adjustments need to be done after your first beta flight? Probably. The plane was slightly out of rig and we were going to address that while it was down for the annual. We'll test fly and see how any normal (as in part of the annual) control cable tension adjustments may or may not have addressed the issue and go from there. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
Jim Burns wrote:
They should have at least had the heart to send a free box of Kleenex when they sold you those ribs. Maximum royal suckage. That's ok, I can always drown my sorrows in free coffee and donuts at the shop on Saturday mornings. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
("Jack Allison" wrote)
Updated pictures he http://s66.photobucket.com/albums/h2...ardrider/Ribs/ Bricks???? Montblack |
| Thread Tools | |
| Display Modes | |
| Piper SB No 836 (alluminum wire replacement) | Mike Noel | Owning | 11 | August 3rd 05 09:05 AM |
| Rogue's Gallery Update -- Talk about diversity! | Jay Honeck | Home Built | 52 | May 11th 05 06:18 PM |
| Rogue's Gallery Update -- Talk about diversity! | Jay Honeck | Owning | 51 | May 11th 05 06:18 PM |
| Rogue's Gallery Update -- Talk about diversity! | Jay Honeck | Piloting | 52 | May 11th 05 06:18 PM |
| replacement rotating beacon for 64 piper cherokee | Patrick Mathews | Owning | 2 | October 1st 03 02:55 PM |
