Wiring Ipaq 3950
Old May 1st 06, 03:57 AM posted to rec.aviation.soaring
Default Wiring Ipaq 3950
I am updating from my old Ipaq 3760 to a 3950. I am not sure which
pin to put the +5V in on. The old 3760 used pin 9 (DCD RS232/USB
+5V). The diagram for the 3950 has DCD RS232 as pin 6 and USB-UDC + as
pin 19.
Can someone tell me the correct pin to use?
Tim
Old May 1st 06, 06:25 PM posted to rec.aviation.soaring
Ipaq 3900 pinouts here, the plug is completely different
between the 37XX and 39XX ranges
http://pinouts.ru/data/ipaq_22p_pinout.shtml
Old May 2nd 06, 11:39 AM posted to rec.aviation.soaring
Is this pinout the same for the H2200?
LX20 + Ipaq wiring Bruce Soaring 2 February 4th 06 10:40 PM
Ipaq and Sunglasses Ray Lovinggood Soaring 2 June 27th 05 08:25 PM
looking for iPAQ 3950 S Schwartz Soaring 2 June 13th 04 03:11 PM
IPAQ Wiring - which pins are used Michael Soaring 9 March 15th 04 08:48 PM
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 4th 03 11:45 PM
