Hatz / Marquart Charger
Old May 1st 06, 08:38 AM posted to rec.aviation.homebuilt
Default Hatz / Marquart Charger
I'm thinking of building one of these in the UK (don't laugh, they still let
us do that sort of thing so long as we promise no to hurt ourselves.)
Has anyone got any relative expriences of the two?
I'm after a plane that will go somewhere (so IAS c100kts as a minimum) with
two adults (so a payload of c 350lb PLUS fuel), has plenty of room in the
main cockpit (for a 6 foot 4 male (me) and a chart and a sandwich and not
throttle me.) Oh it must look nice too.
The Hatz Classic and the Charger are the two I'm deciding between.
These are my preliminary thougts so questions a plenty. I knowb there are
at least one of each in the uk, but not sure where.
The other one i'd thought of was a Stolp Starduster too, but it looks a bit
fussy and skinny. I like the "'30s look" of the other two.
David
Old May 1st 06, 01:26 PM posted to rec.aviation.homebuilt
"david" wrote in message
let
with
bit
David
The Hatz is smaller. It was originally designed around an O-200. There is
a beautiful Marquart Charger here, and it can easily handle big men. Since
you're tall and need to haul a load, go for the Charger and an O-360
Lycoming, or even an O-540. You won't be sorry.
Not taking anything away from the Hatz. It is a great and beloved design,
but you need a Charger.
Old May 1st 06, 04:10 PM posted to rec.aviation.homebuilt
Thanks for that. That was the sort of info I needed. Many thanks.,
PS...where is "here"?
Regards,
David
" jls" wrote in message
let
with
not
are
bit
David
is
Since
Old May 1st 06, 06:00 PM posted to rec.aviation.homebuilt
Western North Carolina. And there are two or three in the Atlanta area.
The lines of the Charger are unforgettable. You will love those swept wings
reminiscent of the Tiger Moth and Jungmeister.
Regards,
David
still
let
with
not
are
bit
David
is
Since
design,
Old May 1st 06, 11:01 PM posted to rec.aviation.homebuilt
Regards,
David
And the swept top wing makes access to the front hole a LOT easier.
That is one thing the Hatz is a little short on...
Only way I can get in is to get backwards, and slide down the back
windshield on my belly. Which get's me in, but I'm facing the wrong
way and "sitting" on the panel...
But the cockpit, once in, is quite roomy and easy to squirm around
right side up.
I'm 6'3 and 195.
Richard
Old May 2nd 06, 08:14 PM posted to rec.aviation.homebuilt
Hmm, wouldn't want to have to egress a Hatz in a hurry then!
I'll go for a Charger I think.
David
"Richard Lamb" wrote in message
wings
Regards,
David
right side up.
I'm 6'3 and 195.
Richard
Old May 3rd 06, 12:12 AM posted to rec.aviation.homebuilt
The Charger is the clear winner on looks.
And Ed Marquart is a wonderfully nice guy. Still working out at
Flabob, active in EAA chaper 1
12v - 12v charger 5Z Soaring 19 December 30th 05 09:58 PM
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 01:19 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
'73 Piper Charger Kobra Owning 1 March 27th 04 08:49 PM
Battery Chargers Mike Rapoport Owning 11 December 2nd 03 11:55 PM
