Really Cool Toy (aviation, and a tiny bit of metal, content)
Old May 1st 06, 08:15 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.crafts.metalworking
Default Really Cool Toy (aviation, and a tiny bit of metal, content)
You airplane geeks will love this. My son bought his three-year-old an Air
Hogs "Twin Fury" plane at Toys-R-Us on sale for $12.95 Saturday. This is a
twin-engined pneumatically powered toy airplane that is very, very clever.
Here's a link to a picture of it.
http://www.amazon.com/exec/obidos/tg...#more-pictures
What is really clever is the design of the motors. These are tiny little
pneumatic motors with only three moving parts each, designed for them by a
consulting firm: http://www.rehkemper.com/airmotor.html The original Air
Hogs pneumatic motor apparently cost 50 cents to make. These new motors are
more efficient and cost 8 cents (!) to make.
When pumped up to the recommended pressure (50 strokes on the supplied pump)
the motors run for roughly 10-15 seconds, initially giving enough thrust to
almost lift the plane on its props. Amazing amount of thrust. Gareth set
his off the first time and claims that it climbed to nearly 300 feet and
flew around for a couple of minutes. The second time it ended up in a high
tree and could not be recovered. No problem; at @ $12.95 he bought another
one. Now that he knows how far it can fly, he's going to be more careful
about where he launches it.
Yesterday I bought one too, only for me.
Bob (Chief Pilot, White Knuckle Airways)
Old May 1st 06, 09:44 PM posted to rec.aviation.homebuilt
For a mere $30, you can get the Air Hogs Aero Ace, a twin engine RC
biplane. There are usually about three of them flying around in the
hangar where I work at lunchtime and breaks. This "toy" has boundary
layer control details molded into the wing and fuselage. It flys about
10-15 minutes on a charge from the charger built into the controller.
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Old May 2nd 06, 01:23 AM posted to rec.aviation.homebuilt
"JKimmel" wrote in message ...
For a mere $30, you can get the Air Hogs Aero Ace, a twin engine RC biplane. There are usually about three of them
flying around in the hangar where I work at lunchtime and breaks. This "toy" has boundary layer control details
molded into the wing and fuselage. It flys about 10-15 minutes on a charge from the charger built into the
controller.
J Kimmel
I saw a guy at Creve Coeur (1h0) airport doing some hangar flying with one of those - pretty cool...
Old May 1st 06, 10:11 PM posted to rec.aviation.homebuilt
On Mon, 1 May 2006 14:15:40 -0400, "Bob Chilcoat"
Neighbor kid and I strapped one of the originals to a 2 liter Dr
Pepper ( what can I say, it's Texas) bottle and plumbed it in.
Pressurized it to 90psi from a compressor. Lost it in some tall weeds
a half mile away.
--Andy Asberry recommends NewsGuy--
Old May 2nd 06, 09:06 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.crafts.metalworking
"Bob Chilcoat" wrote in message
Air Hogs "Twin Fury" plane at Toys-R-Us on sale for $12.95 Saturday.
This is a twin-engined pneumatically powered toy airplane that is very,
very clever. Here's a link to a picture of it.
are more efficient and cost 8 cents (!) to make.
pump) the motors run for roughly 10-15 seconds, initially giving enough
thrust to almost lift the plane on its props. Amazing amount of thrust.
Gareth set his off the first time and claims that it climbed to nearly 300
feet and flew around for a couple of minutes. The second time it ended up
in a high tree and could not be recovered. No problem; at @ $12.95 he
bought another one. Now that he knows how far it can fly, he's going to
be more careful about where he launches it.
Bob,
If you really want to get some air time out of those .. fill it's tank with
butane from one of the cans they use for butane lighters. It goes in as a
liquid and turns to gas at a rate that keeps em running a really long time
I bought my son a car like that years ago and we "discovered" that a
little butane would make it run for blocks on a single fill.
Glenn
Old May 2nd 06, 04:19 PM posted to rec.aviation.homebuilt
Coupla guys at work are goofing with the four-electric-engined version of
these.... the "Air Hog RC Titan." They found them at Costco for about $60.
The scary thing about these is that there is no aerodynamic control of these
planes. Nothing moves except the propellers. All the joystick does is adjust
the speed of the engines.... push the lever to the right, and the left-side
engines turn faster. Pull back on the stick and all the engines rev up.
Needless to say, this results in some highly erratic...yet highly
entertaining...flights. The planes themselves are light but incredibly impact
resistant. They haven't actually broken one yet, even with some fairly nasty
crashes.
Old May 4th 06, 04:51 AM posted to rec.aviation.homebuilt
"Ron Wanttaja" wrote in message
$60.
these
adjust
left-side
impact
nasty
crashes.
There is a fair amount of information on the web about the Aero Ace.
Because it flies so well out of the box, it has developed quite a fan club.
There are some mods that can be done to the controller that improve the
controllability.
The three or four I've seen have all been a little light in the nose.
Shifting the battery pack forward definitely helps.
If you're going to fly outside, removing the lower wing lets it fly a little
faster.
Tim Ward
Old May 2nd 06, 06:35 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.crafts.metalworking
If you really want to get some air time out of those .. fill it's tank with butane from one of the cans they use for butane lighters.
To avoid another TWA 800 tragedy, you'd need a fuel cell inerting
device. Then again, without any lives at risk it'd make an impressive
aerial flamethrower...
Old May 2nd 06, 10:05 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.crafts.metalworking
Why not put a collector on the exhaust, and a small combustion chamber with
igniter. Jet power, anyone? g
Old May 2nd 06, 11:43 PM posted to rec.aviation.homebuilt
On Tue, 2 May 2006 16:05:41 -0400, "Morgans"
Same inquisitive kid as the Air Hog Guppy. He runs a fireworks stand
so he has a supply of rockets. He bought one of the foam gliders with
about a 30" span. We completely covered it with metallic HVAC tape.
Made it amazingly strong and stiff.
We cut the explosive charge off of 3 of the large rockets. The
propulsion motors were joined into a three stage and mounted on the
belly of the glider.
Two lengths of pvc pipe were cantilevered at the guesstimated proper
angle for a launch rail. After the requisite countdown, the fuse was
lit. That thing took off like a...rocket.
The second stage kicked in on the vertical side of a perfect loop. It
completed a 3/4 loop and rolled upright just as the third stage
touched off. I've seen RC jets at 200mph and this thing must have been
doing at least half that when it came over us...headed straight for my
pickup. Luckily, I had been checking the oil and the hood was up or it
would have gone right through the windshield. No fire but there was an
explosion of foam from the impact.
Any use of "we" instead of "he" in this story is inadvertent.
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 12:55 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 11:43 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 05:02 PM
Compiled List of Aircraft-Accessible Aviation Museums Jay Honeck Home Built 23 January 17th 04 11:07 AM
