Trailer ventilation
Old May 1st 06, 06:07 PM posted to rec.aviation.soaring
Default Trailer ventilation
I live in central Europe - where the weather is neither too hot nor too
cold.
Seems to me that in the not too distant past many people fitted little solar
powered extractor fans to their trailers to improve ventilation. Looking
round our club trailer park the other day I noted that only one out of 25
trailers was so equipped.
What are the pros and cons of fitting such fans and is there a trend not to
fit them?
Old May 1st 06, 06:40 PM posted to rec.aviation.soaring
I just added such a fan to my aluminum tube trailer. The job was
simple and easy, took maybe 1/2 hour. If there are any cons, I would
like to here about them before it's too late !
Todd Smith
Old May 1st 06, 06:52 PM posted to rec.aviation.soaring
I believe that the major reason to actively ventilate is to try and
keep the humidity as low as possible inside the trailer. I can't think
of any reason why ventilation would not be used.
Most trailers I've seen with glass gliders inside have these solar
powered fans (I'm in Pennsylvania, where the weather is probably
similar to Central Europe). However, trailers at my gliderport that
contain metal gliders do not have such fans.
As far as trends go, I can only say that my all metal Cobra trailer has
had a solar fan (as well as extra ventilation intakes) for the last 15
years.
-John
Old May 1st 06, 08:39 PM posted to rec.aviation.soaring
cold.
fit them?
If the source of the moisture were from inside the trailer then one of
these vent fans used for drying would make more sense to me. As it is
I believe all they can do is draw outside air, at whatever humidity it
may be, into the trailer. Now if the vent fan is only turned on when
the outside air is relatively dry then perhaps there is some logic for
trying to dry the inside of the trailer. But this scheme is hopeless
when the outside air remains wet for days (weeks?) on end, IMHO.
The route I have chosen is to seal the trailer up as tightly as
possible and install a small dehumidifier inside the trailer. I then
do whatever it takes to get power to the trailer to run the
dehumidifier. The extracted water is drained through a small screened
hole in the bottom of the trailer. It all stays bone dry inside even
during the wet season where it can rain continuously for days or weeks.
The dehumidifier cycles itself on and off as necessary via its
built-in humidistat.
Regards,
-Doug
Old May 1st 06, 08:51 PM posted to rec.aviation.soaring
"Doug Hoffman" wrote in message
cold.
solar
to
fit them?
Regards,
-Doug
Doug
what would you think a max sustain humidity level could be for a set up like
that and still have good result?
Udo
Old May 2nd 06, 10:44 AM posted to rec.aviation.soaring
Udo,
I'm not sure. But I have quickly opened the trailer door during a
steady rain, after 3-4 days of raining, and wiped my hand over the
glider surface. It was dry.
I should mention that sealing the trailer up tight (silicone seal
around the door frame, etc.) is also a good way to keep out bugs.
Regards,
-Doug
Old May 2nd 06, 11:15 AM posted to rec.aviation.soaring
Too much dryness can be a bad thing. It seems that some gaskets in =
difficult-to-reach positions inside the wings can become brittle in =
bone-dry environments. When using an electrical dehumidifier, it may be =
a good idea to set it at least at 50% RH. The goal is to store the =
glider in its trailer at more or less the same relative humidity it =
experiences when outdoors, minus some margin to allow for the quick =
increase in RH as temperature drops throughout the night.
A positive side of trailer vents is that whatever the temperature =
fluctuations, it will not become dripping wet inside even if the trailer =
is left unattended for a long time. Vents also help to moderate internal =
temperatures in hot weather.
My trailer has both a solar vent (with adjustable inlets) and a small =
dehumidifier, but if I lived in a very humid climate I would probably =
seal it in the winter and check every week or so.
Old May 2nd 06, 12:33 PM posted to rec.aviation.soaring
Right. This is what I do. It need not run much to keep things
reasonably dry.
Yes. Certainly a dehumidifier is not appropriate for all situations.
Use judgement. When the wet weather comes, if you live in an area
where it becomes wet for days and weeks at a time, the dehumidifier has
worked great for me. Even when not so wet one can avoid the daily dew
cycle...
Regards,
-Doug
Old May 2nd 06, 02:36 PM posted to rec.aviation.soaring
In a rough calculation, a 40W bulb would raise the temperature inside a =
typical trailer by only a fraction of a degree (although it could create =
a local hot spot if carelessly placed). This would only reduce humidity =
by a couple of percentage points and would be quite less energy =
efficient than using a dehumidifier.
Any thoughts on whether a continuously lit low wattage light bulb =
would=20
provide dehumidification or would it put out too much heat inside a =
glider=20
trailer?
Bryan
Ugly Trailer Ray Lovinggood Soaring 3 December 19th 05 03:56 PM
Trailer hitch inadvertant disconnect Bill Daniels Soaring 5 July 16th 04 03:17 AM
Trailer spare - who woulda thunk? Bill Daniels Soaring 7 May 20th 04 04:47 PM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
Tire Stiffness & trailer swaying chris Soaring 42 October 22nd 03 03:51 AM
