Replacing com antennas
Old May 9th 06, 06:12 AM posted to rec.aviation.owning
Default Replacing com antennas
I've ordered a pair of CI-291 Comant com antennas to replace the well worn
antennas on my Archer. Besides removing any oxidation where the aluminum
base contacts the aircraft and making sure the coax connector is clean and
serviceable and the mechanical connection robust, are there other mounting
considerations? For instance, is a conductive grease used between the
antenna base and the aluminum panel? Does Comant include any extra goodies
for the installation?
The 3 mounting holes in the new antennas are in exact alignment with the old
antennas. The interesting part will be backing the spinning nuts in the
tail cone while removing the outside screws. I should be able to capture
the coax with nylon ties to keep them from falling back into the fuselage
while preparing to mount the new antennas.
Best Regards,
http://photoshow.comcast.net/mikenoel
Old May 9th 06, 04:23 PM posted to rec.aviation.owning
Mike: Does your new antenna have a BNG terminal.? I've been told that
is the way to go instead of a separate coax ground wire. Maybe I'm
confused what you have.
Larry
Old May 9th 06, 06:19 PM posted to rec.aviation.owning
Hi Larry. I think what is on the end of the coax is called a male bnc
connector.
Mike Noel,
Tucson, Arizona
'Men never do evil so completely and cheerfully as when they do it from
religious conviction.'
-Blaise Pascal
"Larry" wrote in message
Larry
Old May 9th 06, 08:08 PM posted to rec.aviation.owning
"Mike Noel" wrote in message
connector.
Mike Noel,
Tucson, Arizona
Hi Mike,
Just as a point of clarification for all (not specifically aimed at you...):
BNC: A "cam-lock" style connector needing only about 1/4 turn to lock in
place via curved channels that ride down pins on the opposite connector.
UHF: 1/4" to 1/2" diameter threaded connector which needs multiple turns to
screw into place.
One of these two types of connectors are usually what you'll find at the end
of a Coaxial cable. The UHF connectors of the world have pretty much been
replaced by BNC connectors, but you still find UHF on older wiring.
Jay Beckman
PP-ASEL
Chandler, AZ
Old May 10th 06, 09:13 PM posted to rec.aviation.owning
I can now partially answer my own question since I've received the antennas
from Spruce. The only thing in the box is the antenna and a base gasket.
I'll need to purchase new nuts and screws and evidently no 'conductive
grease' is needed.
Best Regards,
news
goodies for the installation?
old antennas. The interesting part will be backing the spinning nuts in
the tail cone while removing the outside screws. I should be able to
capture the coax with nylon ties to keep them from falling back into the
fuselage while preparing to mount the new antennas.
Best Regards,
Old May 11th 06, 12:21 AM posted to rec.aviation.owning
On Wed, 10 May 2006 13:13:56 -0700, "Mike Noel"
grease' is needed.
It's probably just my ignorance, but the only conductive grease I've
ever encountered in electronics is the stuff you used to use between
the bottom of a power transistor in a TO3 can and the mica washer.
(Or was it between the washer and the heat sink?) It was thermally,
rather than electrically, conductive.
Don
Old May 11th 06, 02:23 AM posted to rec.aviation.owning
Don ...
Both the graphite grease and the copper grease we use on spark plugs to make
them easier to remove are electrically conductive as well as thermally
conductive. HOWEVER, no such grease is needed (or wanted) on the COM
antenna(s).
On the other hand, I generally put a VERY thin film (almost a whisper) of
Dow Corning silicone grease (NOT SILICONE SEAL) on both sides of the rubber
gasket to keep rainwater out of the aircraft.
Don
Old May 11th 06, 06:31 AM posted to rec.aviation.owning
Evidently the antennas have a special coating over the fiberglass to allow
them to conduct away static charges that can build up. I think the charge
is allowed to pass to the airframe via the antenna base and the mounting
screws and then out the static wicks. If the static is allowed to build up
it is said to cause noise in the radio. I would imagine the idea of
conductive grease was to allow a more robust path for static drain to the
airframe.
The countersink surfaces on the antenna base for the mounting screws are
bare metal. I suppose this is intentional to allow static discharge. When
corrosion occurs at these small conductive surfaces perhaps the performance
of the antenna will be compromised when conditions are right for static
buildup. I understant that when an antenna ages and the conductive coating
on the outside of the fiberglass degrades, this can also cause static
problems. Supposedly these are the rational for replacing antennas when
installing new radios.
Best Regards,
"Don Tuite" wrote in message
antennas
grease' is needed.
Don
Old May 11th 06, 06:41 AM posted to rec.aviation.owning
Where do you get the "evidently"?
Evidently
Old May 11th 06, 03:28 PM posted to rec.aviation.owning
What I was proposing is based on discussions or articles I've run across on
usenet, and some dealer sites like Avionics West. I mean them as points
for further discussion, not well know facts.
Best Regards,
"RST Engineering" wrote in message
Evidently
MoGas users: Ethanol replacing MTBE John Piloting 167 May 5th 06 08:31 PM
GPS Smart antenna's Chris Soaring 4 July 13th 04 07:18 AM
Do ADF antennas need replacing if changing the receiver? [email protected] Owning 5 December 11th 03 10:13 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 02:51 AM
Replacing Generator with Alternator Thomas Ploch Owning 2 October 11th 03 03:36 AM
