Turbine to RC transition
Old May 15th 06, 06:03 AM posted to rec.aviation.rotorcraft
Default Turbine to RC transition
Some friends bought me a really spiffy coaxial RC helicopter for my
birthday. Holy canoli these things are a stinkin blast! A little humbling at
first too, it took me a while to figure out the trim hickamajobs, and flying
one without it being trimmed is damn near impossible. I crashed pretty badly
once and it cost me a set of rotor blades, truly embarassing.
I've seen some comments that they fly like the bigger ones, and to a
limited extent I agree, but mostly its its own animal and my more general
knowledge only helped a little. I mostly have to follow the thing around and
stay behind it so that I don't get confused with the controls. Trying to
visulize being inside is still very confusing for my old synapses if its
tail is anywhere between 9 and 3 o'clock.
The whole reversed sensing / control thing led to a really simple circuit
idea that could make it so that the controls were always oriented for the
observer/controller. If you put an ADF circuit and a slightly more
complicated antenna on the helicopter so that it listened to the phase and
doppler from the transmitter's frequency, you could pretty simply make it so
the helicopter always knew where it was relative its controller, and mix it
in to the servo controls. This way left is always left, and right is always
right. The circuit would be pretty dirt cheap. Anyone know if this has
already been done?
I know the rc purists will say bah , and poo poo the whole idea, but truth
is youre cheating anyways with that lil yaw gyro keeping the tail in place
automagically. Besides, my idea isnt just applicable to these lil choppers,
it would work for every ROV that is controlled by an observer physically
watching it.
Bart
Old May 15th 06, 06:12 AM posted to rec.aviation.rotorcraft
"B4RT" wrote in message
birthday.
I suspect you don't realize this is not a radio control NG.
Old May 15th 06, 10:29 AM posted to rec.aviation.rotorcraft
birthday.
I suspect you are an idiot.
Old May 15th 06, 03:56 PM posted to rec.aviation.rotorcraft
"JohnO" wrote in message
birthday.
Have a bad day there JohnO? Don't over-read my post.
I've been called worse than that by better than you. Stay focused on the
discussion.
Old May 15th 06, 08:47 PM posted to rec.aviation.rotorcraft
birthday.
Nah, pretty good day actually. Why?
I'm sure you have!
Stay focused on the
discussion.
Thanks for the tip.
Old May 15th 06, 02:11 PM posted to rec.aviation.rotorcraft
"jim.blakely" wrote in message
news:75U9g.4970$Sh3.4657@trnddc05..
Yes, I know that. I also know that theres some very loyal readers in here
who fly them. I was commenting on the differences between my 3000lb
helicopter and three 3ounce one, hence the title.
Bart
Old May 15th 06, 01:23 PM posted to rec.aviation.rotorcraft
Insults from full sized pilots who don't care about RC aside, that's an
interesting idea about the ADF and antenna circuit. As an RC helicopter
pilot, I'm not sure how it's going to help you. You still need to direct
the model to where you want it to go, relative to where it is and it's
orientation to you. I guess I'm missing the point, but it seems to me that,
as hard as RC helicopter are to "learn" to fly (they're really not that bad
once you know how. You full size pilots should understand that statement!
;-) ), that if what you're suggesting would work, someone would have tried
it by now!
By the way, I'm glad you're enjoying the coaxial model, and I don't mean to
burst your bubble but, of the folks I know that have tried them, most say
the new electric coaxials are dirt simple to control relative to the
standard configuration (main and tail rotor) style models. If you think
what you have is challenging, try a standard model. ;-) You're right
though, they are a stinkin blast! :-D
Fly Safe,
Steve R.
at first too, it took me a while to figure out the trim hickamajobs, and
flying one without it being trimmed is damn near impossible. I crashed
pretty badly once and it cost me a set of rotor blades, truly embarassing.
and stay behind it so that I don't get confused with the controls. Trying
to visulize being inside is still very confusing for my old synapses if
its tail is anywhere between 9 and 3 o'clock.
so the helicopter always knew where it was relative its controller, and
mix it in to the servo controls. This way left is always left, and right
is always right. The circuit would be pretty dirt cheap. Anyone know if
this has already been done?
choppers, it would work for every ROV that is controlled by an observer
physically watching it.
Bart
Old May 15th 06, 07:30 PM posted to rec.aviation.rotorcraft
which coax RC model did they give you, and are real kamov style twin
rotors easier to fly?
Steve Roberts
Old May 19th 06, 12:45 PM posted to rec.aviation.rotorcraft
I've often thought about some orientation aid for RC aircraft, but I
think it would cost too much to make something that was accurate. You
don't really need it for helis anyway, since you can fly in any
direction. I guess I'm saying "bah".
And we're not cheating with the heading-hold gyros! It is possible
to fly an RC heli without a gyro, but it's a lot of work. Esspecially
in the wind. There is an inbetween option; most hobby-grade gyros have
a "rate" mode, where it simply slows rotation to sane speeds, rather
than holding it in one direction.
Those cheap coaxials look like fun. If you want something that will fly
a bit more like a real heli and will do aerobatics, the T-rex is a
really good little machine. All the fun of a "real" RC heli, but not
quite as expensive.
RC helis will have to do for me untill I can afford lessons in a
full-scale.
Old May 19th 06, 04:21 PM posted to rec.aviation.rotorcraft
I don't have a clue how something like that would work. It's just a matter
of learning the reflexes for the different positions. Flying backwards or
sideways only adds other control requirements that aren't necessarily
intuitive. There's also the added fact that all the right side up forward,
backwards, and sideways stuff can be done while flying inverted which
scrambles the required control inputs yet again. In the long run, I firmly
believe that by the time you get some kind of electronic aid working for all
of this, you would probably have worked it out in your head and be able to
fly it more smoothly to boot!
As someone who did his initial hover training without the benefit of a gyro,
they were just becoming popular back in 1982 and I didn't know they existed
for the first few months that I tried to learn to hover, it's a lot easier
to fly the model in a modest (10 mph or so) breeze. The model wants to
weather vane into the wind which becomes a natural yaw damper. The gyros we
had back then were mechanical. A couple of brass fly weights attached to
the output shaft of an electric motor that was mounted on a gimble with a
potentiometer like those used on the control sticks of the RC transmitter.
All it was, was a yaw damper and, by todays standards, not a very good one!
The modern "gyro" is all solid state and all of them that have heading hold
capability also have what we call a "normal" mode which behaves essentially
like the old mechanical units did 20 years ago, albeit with much better
precision.
quite as expensive.
Generally true although you have to be careful with models like the T-Rex.
They offer this model in a fully upgraded version with all the bells and
whistles. It sells in the neighborhood of $500 or so, give or take a little
depending on which hobby shop's advertisement you read. Then you get to buy
batteries, RC flight control servos, receiver, gyro, etc. You can build and
fly a "nice" IC (internal combustion) powered model for that kind of money!
Even those who buy the base version of the model eventually start upgrading
it as the stock plastics parts don't handle a crash as well and over time,
they've got all the metal upgrades on there, only they've paid for them one
at a time so now that $500 model turns out to be a $650 model. They can get
you, one way or the other!
full-scale.
That's one area that you and I definitely have in common! :-(
Good luck & Fly Safe,
Steve R.
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
Rick Stitt, Joe Rinke, Rinke Aerospace, BJ Schram, Mini 500, Turbine, Helicopter, Kit TurbineMini Richard Rotorcraft 2 January 24th 04 01:15 AM
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit TurbineMini Richard Rotorcraft 0 January 15th 04 11:48 PM
TRUTH OF THE MINI-500 TURBINE CONVERSION Dennis Chitwood Rotorcraft 10 January 7th 04 05:33 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
