Question for controllers
Old May 15th 06, 08:10 PM posted to rec.aviation.piloting
Default Question for controllers
In your controller training, are situations addressed concerning aircraft
which request priority but do not declare an emergency? Is there any
guidance in the Controllers' Handbook?
D.
Old May 15th 06, 09:10 PM posted to rec.aviation.piloting
http://www.faa.gov/ATpubs/ATC/INDEX.HTM
to answer the last part of your question.
Bob Gardner
"Capt.Doug" wrote in message
D.
Old May 16th 06, 12:20 AM posted to rec.aviation.piloting
The document says (very roughly) if in
doubt handle as emergnecy even if not
declared by aircrew.
This reminds me of a time when I was
a dual Pilot Under Instruction.
I was flying the aeroplane (almost
ready for solo) when (as we later
found out) a drive gear to one of the
magnetos lost some teeth.
We were 500' AGL climbing out from takeoff.
The engine immediately lost a lot of power
and sounded very bad. The instructor took over
control and turned 180 degrees and made
a downwind landing. The engine did not get worse.
IIRC we were able to maintain altitude more or less.
I was surprised that he did not declare an emergency
and only requested clearance to land on the reciprocal
runway. The tower said nothing either but as we approached
I could see that the fire crews were out.
I did not pursue my flying and so have not really
much more experience that I had then but
I still feel that not declaring an emergency was
not the right thing to do.
He was however a military instructor which I
assume indicates quite a bit of flying experience.
He did, of course, take the opportunity to
demonstrate and talk through the issues
and techniques of downwind landing which
I had not yet covered!
The engine lost power since the faulty
mag was still firing quite a lot but not at
the right time. Given more altitude various
mag switch fiddling would have presumably
restored power.
Anyway, the point is that the UK controllers
behaved as described in the document
referred to in the previous post and
called out the crash crew even though no
emergency had been declared.
Old May 16th 06, 12:39 AM posted to rec.aviation.piloting
So who files out the paper work later?
I ask because I once arrived at a major U.S. West Coast airport, and
upon extending the landing gear, had no light. I was left base at the time,
so I asked for a "right 270" to do a quick troubleshoot. Sure enough, the
bulb was bad. After landing I was followed by the equipment, and when I
stopped, the crash rescue guys wanted to know the "nature of my emergency".
I told them I had no emergency, and they left. It took two months of talking
to FAA folks to convince them there was no emergency in the first place.
Al
restored power.
Old May 16th 06, 02:20 AM posted to rec.aviation.piloting
The rule does not require the pilot to say the "magic words"
to have an emergency, nor does it mean that if the words are
not spoken an emergency does not exist. The rules also
require a report IF traffic priority is given. The tower
saw that you were doing something out of the ordinary. They
may have extended another airplane [perhaps an airliner] and
if the airline asked why their fuel bill was $1,000 higher
and 10 minutes late, the tower needs your statement, really
just a N-number, name to CYA.
If you mentally declare an emergency to yourself, you can do
what ever is needed to solve the problem, including
violations of airspace, minimums or clearance. For
instance, you're solid IFR/IMC and have a total electrical
failure which is not covered by any regulation except
pilot's emergency authority. You can shout at your dead
radio, until you get on the ground somewhere nobody will
know the nature of your emergency. Your navigation becomes
dead reckoning to the nearest area of known VMC.
Controllers are there to help, but unless you say emergency
they're not obligated to give you priority handling. There
is no investigation, no third degree or rubber hose, declare
the emergency, get on the ground safely, tell them your name
and thanks.
James H. Macklin
ATP,CFI,A&P
some support
"Al" wrote in message
airport, and
base at the time,
Sure enough, the
of my emergency".
months of talking
the first place.
| Al
| wrote in message
approached
| restored power.
Old May 16th 06, 02:48 PM posted to rec.aviation.piloting
You're just makin' this **** up. Nowhere does it spell out that if you
do something "unusual" does that then require a report. In the
situation where the gear light failed you ask to have a little
manuvering space to check it out. We give you that and you tell us it
was the bulb. You get the equipment as a matter of course. Whether you
think it is an emergency or not is irrelavant, we do so therefore it is
an emergency. You land safely and there are two lines on the daily log.
Fiorst line states that N12345 has gear difficulty and that the trucks
were rolled. Second line states you landed safely. That's it and the
end of it. That log, like all daily logs, gets kept for a year. They
are not forwarded on to anybody. You will not be asked for a report.
If there is an incident or accident you may be called by the tower for
some information. We had one of the local C310's that is used by a 135
air taxi outfit to deliver bank checks everyday fold up its right main
three weeks ago on landing. Gear ups are by definition an incident and
not an accident. Normally the airport and FBO can get a gear up off the
runway pretty quickly however this time the owner of the plane demanded
that they lift up the plane using two cranes, like you're supposed to to
prevent further damage. It took an extra half hour to locate so the
plane tied up our main runway for over an hour. Many airliners, air
taxi's and biz jets in holding while all of this going on. We never
talked to the pilot of the 310 after the gear up, no need to. The fire
truck guys have their own paperwork but that has nothing to do with the FAA.
Old May 17th 06, 12:27 AM posted to rec.aviation.piloting
What paperwork?
time, so I asked for a "right 270" to do a quick troubleshoot. Sure
enough, the bulb was bad. After landing I was followed by the equipment,
and when I stopped, the crash rescue guys wanted to know the "nature of my
emergency". I told them I had no emergency, and they left. It took two
months of talking to FAA folks to convince them there was no emergency in
the first place.
Why bother? You feel there was no emergency, they believe there was. So
what?
Old May 17th 06, 05:46 PM posted to rec.aviation.piloting
nk.net...
What paperwork?
my emergency". I told them I had no emergency, and they left. It took two
the first place.
what?
That's pretty much how it worked out. The GADO sent representitives to
my home airport, to "ask around" about the "Gear emergency", but I was out
of town at the time. When I got back they had left me a note to contact the
GADO, and I learned they had spoken to most of the maintenance folks on the
airport looking for "Indications of an un-reported problem". I called them
on my return, and after explaining several times that is it was the bulb,
they backed off. I believe the phrase was "Let me off this time." It was
just another incident in a long cynical distrustful relationship with the
FAA GADO's.
On a brighter note, I recently jumped through the hoops to get my second
class medical, after 15 years of no flying, and was treated very well by the
Seattle office of their Aeromedical division. Some of their people(One
Barbara Martin in particular) were extremely helpful. They seemed to be
handling medical request in near real time, the delays I saw were in days,
not weeks or months. This is not the FAA I new twenty years ago.
Al
Old May 17th 06, 07:22 PM posted to rec.aviation.piloting
Al wrote:
[snip]
That sheds light on something I experienced while I was training for my
PPL. I was landing anfter my 4th solo and (in retrospect) got the
infamous C-172 nose wheel shimmy. I didn't what was happening, but I
thought the plane might shake itself to peices. I called the tower and
told them that I was now making a full stop landing rather than touch
and go and I had a severe vibration. After I got the plane slowed down
to a walk, it stopped shaking. I called the tower and told them I was
taxiing in. They asked if I needed any assistance and I said no. I then
heard them call the trucks and send them back to the fire house. I
never declared (nor really thought I had) an emergency, but they rolled
the trucks anyway. I wondered about that at the time, but I didn't call
the tower to ask...
John Stevens
PP-ASEL
Old May 16th 06, 05:32 AM posted to rec.aviation.piloting
Some times, the controller knows when to not ask questions or offer advice..
just watch, keep everyone else out of the way.. and pick up the phone to
alert the fire crew.
BT
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
