Pump driven prop????
Old May 16th 06, 07:03 PM posted to rec.aviation.homebuilt
Default Pump driven prop????
On the stern of some paddle-wheelers are the paddles. One I've been on had
its paddle-wheels run by pumps. Pump line ran out of the engine room and
terminated in a smallish box next to/attached to the wheel's axle.
Would that idea work for aircraft. Pump driven prop?
One advantage would be aerodynamic streamlining of the cowl. The nose of the
plane could be almost bullet shaped ...engine might be mid plane - anywhere
really. Engine's prop shaft no longer an issue.
Montblack
Old May 16th 06, 07:06 PM posted to rec.aviation.homebuilt
Mountblack said:-
Yes, however:-
Hydrostatic drives shuch as this are fairly common in
heavy construction equipment and the like however
there is a problem.
There is too much loss even for ordinary car use and the
fuel consumption is unacceptably poor.
I would guess that this would be an even more serious
issue in aircraft.
Old May 16th 06, 09:02 PM posted to rec.aviation.homebuilt
wrote
Yes, however:-
there is a problem.
issue in aircraft.
Indeed, there would be, and one large problem is called weight. It wo8uld
be extremely heavy.
Also, those loss issues bring up another problem. When you have loss, what
happens to that energy? Energy can not be created or destroyed, and that
energy put into loss shows up as heat. Boatloads of heat that must be
dissipated, and that will take a lot of radiator, and air to go through it.
That will cause wind resistance, which will slow the plane, so much as to
make a biplane seem speedy.
Old May 16th 06, 09:36 PM posted to rec.aviation.homebuilt
Mountblack said:-
Yes, however:-
there is a problem.
issue in aircraft.
not to mention heat issues due to friction and the fact that it adds another
link in the chain to fail.
oh, and weight. those hydraulics aint light
Old May 16th 06, 09:46 PM posted to rec.aviation.homebuilt
My guess is that this offers certain advantages such as preventing
the paddles from back-driving the drive train when the engine is
throttled down and also making it possible to use valves to reverse
the paddles direction.
Such a system will also be more efficient for low speeds than for
high speeds.
A drive shaft is a far more efficient means to transfer mechanical
energy from the engine to the prop.
Consider the P-39 Airacobra. Engine was behind the pilot, the
prop out in front.
FF
Old May 19th 06, 11:21 PM posted to rec.aviation.homebuilt
Too heavy to fly but....
here is a hydrostatic diesel hog though.
http://www.findarticles.com/p/articl...70/ai_n8681022
"Montblack" wrote in message
the plane could be almost bullet shaped ...engine might be mid plane -
anywhere really. Engine's prop shaft no longer an issue.
Montblack
Why does a prop ice up so apparently readily? Mike Rapoport General Aviation 3 November 8th 05 02:52 PM
Engine driven fuel pump necessary with gravity feed tank?? Lycoming RonLee Home Built 2 May 8th 05 06:10 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 08:08 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
