Transmissions
Old April 1st 04, 02:41 PM
Hankal
Default Transmissions
November 12345, a Cessna 172, 20 miles northeast of Sugarloaf Mountain, level
VFR seven thousand five hundred, en route to Winston-Salem, North Carolina."
For those who like to write lists, it would look like this:
1) FULL callsign;
2) Type aircraft;
3) Current location;
4) Current altitude and altitude to which you are climbing/descending; and,
5) Destination.
There is a method behind my madness. Most Center controllers will find this
format comfortable and oddly familiar. That's because it's the format that the
flight plan is written on a flight progress strip.
Guess I will not listen to hangar talk and continue giving the whole spiel,
until advised different.
Hank
Old April 1st 04, 03:09 PM
Steven P. McNicoll
"Hankal" wrote in message
Mountain, level VFR seven thousand five hundred, en route to
1) FULL callsign;
2) Type aircraft;
I would combine the two, "Skyhawk 12345". Please, do not combine them as
"Cessna 172 12345"
Old April 1st 04, 03:29 PM
John T
spiel, until advised different.
The part you quoted isn't quite in context without the preceding section:
quote
....I've been told by some approach controllers that they want all the flight
information on the initial check in. I can't imagine why, but I won't argue
about it. I prefer this method straight out of the AIM.
"Atlanta Center, Cessna 12345 requesting VFR advisories."
That serves to get my attention. It's short and lessens the chance that
you'll transmit at the same time someone else is transmitting. It's just a
good idea, period. Once I'm off the landline, I'll say, "Calling Atlanta
Center, say again." You, realizing that Center controllers are slow, will
say, "Atlanta Center, Cessna 12345 requesting VFR advisories." I'll hit the
CODE key on my keyboard, type in N12345 and press ENTER. Seeing as it's me
doing the typing, I'll go back and make sure I really hit the CODE key this
time, type in N12345 and press ENTER. (I always said I could be a great
controller if I could just learn to type.) The computer will spit out a
beacon code and I'll say, "Cessna 12345 squawk 3231 and go ahead."
/quote
The quote above is from a Center controller whose job is a bit different
from a TRACON controller. If providing all information on the initial
call-up works for you in your area, by all means continue doing so.
However, if you're not already in the system (e.g., known to the
controller), the controller may spend a few seconds scanning his scope for
your tail number when you call him up the first time. That may cause a
complete re-transmission of your request which ties up the airwaves even
longer.
To minimize this possibility, be sure to use "VFR" right after your tail
number on initial call-up.
Another source of information is AIM §4-2-3.a.1:
quote
1. The terms initial contact or initial callup means the first radio call
you make to a given facility or the first call to a different controller or
FSS specialist within a facility. Use the following format:
(a) Name of the facility being called;
(b) Your full aircraft identification as filed in the flight plan or as
discussed in paragraph 4-2-4, Aircraft Call Signs;
(c) When operating on an airport surface, state your position.
(d) The type of message to follow or your request if it is short; and
(e) The word "Over" if required.
EXAMPLE-
1. "New York Radio, Mooney Three One One Echo."
2. "Columbia Ground, Cessna Three One Six Zero Foxtrot, south ramp, I-F-R
Memphis."
3. "Miami Center, Baron Five Six Three Hotel, request V-F-R traffic
advisories."
/quote
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Old April 1st 04, 03:41 PM
Paul Tomblin
In a previous article, "John T" said:
EXAMPLE-
Memphis."
advisories."
/quote
It's a good thing they put dashes between the letters there to indicate
you spell those things out. I've been saying "viffer" and "eye-fer" all
this time.
"Tech Services - We Aim To Please, We Shoot To Kill"
-- H. Wade Minter, ASR
Old April 1st 04, 04:10 PM
Hankal
"Cessna 172 12345"
I never use Cessna 172. Always use Skyhawk. Of course some controllers come
back "say aircraft"
Old April 1st 04, 07:39 PM
John Bishop
You might know what your aircraft is, but don't expect everyone else to do
so. You are in a 172 offficially, so why not announce yourself as so?
I fly from a major international airport, they aren't interested that I fly
a brand new Archer, they tell all the 737's and Airbus's to "look out for
the Cherokee on base" It's a PA28 to them.
John
"Cessna 172 12345"
come
back "say aircraft"
Old April 1st 04, 07:43 PM
John Bishop
Here in the UK, the controllers like your first call to be just the approach
name and your callsign. Around London, they are usually very busy and often
will reply with a message to standby. When they come back to you, then you
give full details and intentions.
There is no point transmitting everything first call if he's not ready to
talk to you
John
"John T" wrote in message
ws.com...
quote
flight
argue
this
/quote
longer.
quote
or
EXAMPLE-
Memphis."
advisories."
/quote
John T
Old April 1st 04, 07:50 PM
Steven P. McNicoll
"John Bishop" wrote in message
to do so. You are in a 172 offficially, so why not announce yourself
as so?
What makes "172" any more "official" than "Skyhawk"?
Old April 1st 04, 08:00 PM
Ben Jackson
back "say aircraft"
I've had controllers come back and say "say type aircraft" in response
to a spiel including "cessna 1 7 2 slant golf".
Ben Jackson
http://www.ben.com/
Old April 2nd 04, 01:28 AM
John R Weiss
"Steven P. McNicoll" wrote...
That will work, now that the A-4 has been retired from the Navy... ;-)
For those who don't have the list in front of them, a couple old rule of thumbs:
Initial contact:
Callsign
Altitude
"XYZ Center, Skyhawk 12345, 7,500'."
Then, after the controller responds,
Who you are
Where you are
What you want
"XYZ Center, Skyhawk 12345, 20 miles NE of Sugarloaf, 7,500', enroute
Winston-Salem, request VFR flight following."
Transmissions? Hankal Instrument Flight Rules 7 April 3rd 04 04:05 PM
