Hello,
I'm looking for a high efficiency Aux Power Unit. I'm actually building a electric car, and want some way to recharge besides plugging in. I'd like to go with a microturbine/turbine for both space and efficiency concerns. I'm looking for anything over 30 kW of power, with efficiency being my main concern. Gas stations havent started stocking Jet-A, so I guess you can add that to the list of requirements. I'll probably be using my own alternator/generator, a secondary 40kW unit, but I couldnt complain too much if the unit came with one. Any sort of links at all would be really useful. You guys are really the only domain I know of that might be able to help with something like this. Even links to other good message boards would be great. I really appreciate it! Thanks mates, McCoy. |
Assuming that your interest in some kind of fuel efficiency why not
consider one of the small Wankels? They can be had in the power range you are looking for and are far more fuel efficient than a turbine. Weight and size is not that much different either. http://www.rotary-xr40.com/rotary3.htm There are also Wankel powered aircraft APU's available, but the price is steep. ========== Leon McAtee |
Unfortunately, neither Wankel or small turbines are very efficient.
Best bet currently is a diesel, but they are not especially light. tom |
![]() "fake mccoy" wrote in message oups.com... Hello, I'm looking for a high efficiency Aux Power Unit. I'm actually building a electric car, and want some way to recharge besides plugging in. I'd like to go with a microturbine/turbine for both space and efficiency concerns. I'm looking for anything over 30 kW of power, with efficiency being my main concern. Gas stations havent started stocking Jet-A, so I guess you can add that to the list of requirements. I'll probably be using my own alternator/generator, a secondary 40kW unit, but I couldnt complain too much if the unit came with one. Any sort of links at all would be really useful. You guys are really the only domain I know of that might be able to help with something like this. Even links to other good message boards would be great. I really appreciate it! Thanks mates, McCoy. At 30 KW, the Capstone turbine would fit your bill. Only one moving part, can be set up for diesel or natural gas. Pricey, though. http://www.microturbine.com/ Tim Ward |
Capstone hides their fuel specific pretty well, but you can tease it
out. .57 lb/hp/hr. Very good for a small turbine with a single stage compressor - but even an awful 4 stroke piston engine should be about ..45. A serious stratified charge engine can get down around .33. I think the record is about .25. The Capstone uses some very clever air bearings, but they won't stand up to any gyroscopic force. Put them in an airplane and try to turn, you'll crash the bearings. |
Richard Riley wrote:
Capstone hides their fuel specific pretty well, but you can tease it out. .57 lb/hp/hr. Very good for a small turbine with a single stage compressor - but even an awful 4 stroke piston engine should be about .45. A serious stratified charge engine can get down around .33. I think the record is about .25. The Capstone uses some very clever air bearings, but they won't stand up to any gyroscopic force. Put them in an airplane and try to turn, you'll crash the bearings. The OP does explicitly say that this is for use to recharge an electric vehicle instead of plugging into the mains, so that won't be an issue. However, if I was making an electric vehicle with an APU, I'd certainly want it to be able to run 'direct', too. Even the best batteries only put out what, 75% of the charge put into them. Running direct means that you can in principle get 25% better mileage out of the same amount of fuel, save some wear and tear on the batteries, and not have to stop so often. |
![]() "Ian Stirling" wrote in message ... Richard Riley wrote: Capstone hides their fuel specific pretty well, but you can tease it out. .57 lb/hp/hr. Very good for a small turbine with a single stage compressor - but even an awful 4 stroke piston engine should be about .45. A serious stratified charge engine can get down around .33. I think the record is about .25. The Capstone uses some very clever air bearings, but they won't stand up to any gyroscopic force. Put them in an airplane and try to turn, you'll crash the bearings. The OP does explicitly say that this is for use to recharge an electric vehicle instead of plugging into the mains, so that won't be an issue. However, if I was making an electric vehicle with an APU, I'd certainly want it to be able to run 'direct', too. Even the best batteries only put out what, 75% of the charge put into them. Running direct means that you can in principle get 25% better mileage out of the same amount of fuel, save some wear and tear on the batteries, and not have to stop so often. Lead-acid puts out about 75%, Lithium can go as high as 95%. Capstone has already installed them in buses, so ground vehicle apps aren't ground-breaking. |
Tim Ward wrote:
"Ian Stirling" wrote in message ... Richard Riley wrote: snip However, if I was making an electric vehicle with an APU, I'd certainly want it to be able to run 'direct', too. Even the best batteries only put out what, 75% of the charge put into them. Running direct means that you can in principle get 25% better mileage out of the same amount of fuel, save some wear and tear on the batteries, and not have to stop so often. Lead-acid puts out about 75%, Lithium can go as high as 95%. Well - there will be some losses in the converter - even if it's a couple of percent either way, that's close to 10% power loss. I diddn't know that lithium was that high. Capstone has already installed them in buses, so ground vehicle apps aren't ground-breaking. Unless it's an electric earthmover ![]() (I have seen one, but it was marketed for use by 5-8 year olds) |
Winter mechanical vario reading high | Alan Meyer | Soaring | 13 | April 13th 06 02:38 AM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Viagra and the Mile High Club | Cub Driver | Piloting | 17 | May 28th 04 09:22 PM |
AIM-54 Phoenix missile | Sujay Vijayendra | Military Aviation | 89 | November 3rd 03 09:47 PM |
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS | MT. DIABLO HIGH SCHOOL PHOTOS | Home Built | 1 | October 13th 03 03:35 AM |
