Anyone Own a Garmin GTX 327 Transp??
Old May 23rd 06, 07:14 PM posted to rec.aviation.owning
Default Anyone Own a Garmin GTX 327 Transp??
Our 327 is a few weeks old. According to the manual, the unit is
supposed to have Auto Mode switching from STBY to ALT on takeoff, and
then back again on landing. The takeoff part works fine....as soon as
the wheels leave the ground, the unit will switch to ALT and the timers
will start.
But it doesn't return to STBY on landing. That has to be done
manually. I've fiddled with the Configuration Menu abit according to
the manual and changed the Delay Timer to 0, but nothing seems to make
a difference.
What am I missing??? And I'm not sure what the Delay Timer is...is it
in minutes? seconds? For what? I've posted a question to garmin.com
but thought I would ask here as well.
THanks!!
--Jeff
Old May 23rd 06, 07:30 PM posted to rec.aviation.owning
a difference.
I have the GTX330, which has the same feature, and it also does not
automatically return to standby at the conclusion of a flight. I haven't
yet bothered to investigate the reason, so if you receive an answer on the
Garmin forum, please post the reply here.
Peter
Old May 23rd 06, 07:38 PM posted to rec.aviation.owning
a difference.
I've the GTX330, connected to a GNS430. I've a fixed gear airplane
(Cessna 182) so the switch from sby to active and back is done based on
groundspeed. No problems so far, I've had this combo for two years now.
-jav
Old May 23rd 06, 07:39 PM posted to rec.aviation.owning
a difference.
-jav
Old May 24th 06, 08:19 AM posted to rec.aviation.owning
Our 330 doesn't go to standby, but rather to a mode called GND for
ground. Not quite sure what the difference is, but I think I have read
somewhere it is a special mode S thing telling ATC you're on the ground.
The delay timer is for you to still transmit an active transponder signal
as logn as you are still on the runway, taxiing off it. Default is 30
seconds, I think. Of course, the automatic on function doesn't give you
that option when taxiing onto the runway for take-off, something that
bother me a little.
Thomas Borchert (EDDH)
Ray,
KPVD,
for example requires the transponder be on while on any active part of
the airport.
"on" as in ALT?
Old May 24th 06, 01:14 PM posted to rec.aviation.owning
Yep, my mistake. My unit also goes into GND mode.
What I was recalling is that the TIS traffic call-outs occur while in GND
mode (assuming at an airport providing TIS). To stop the call-outs while
on the ground, I would hit the standby mode during taxi. This is where I
was confusing my issue with the OP 's issue.
Peter
Old May 24th 06, 01:22 PM posted to rec.aviation.owning
Ray,
KPVD,
the airport.
"on" as in ALT?
Yes. They want the transponder replying with your assigned squawk code.
The mode 3/A setting is probably OK too, but stdby is not.
Old May 24th 06, 01:51 PM posted to rec.aviation.owning
Garmin hasn't yet responded to my question posted to their customer
service site. Thanks for clarifying the purpose of the Delay Timer.
It makes sense.
I live in the Washington DC area and fly in the dreaded ADIZ. You must
have a valid squawk before takeoff and have it on until wheels touch
down. If you accidently hit 1200 before that, you get a
not-so-friendly call from the TSA/FAA/FBI/CIA/NSA.... Pilots have been
given warnings and lost tickets for all kinds of transponder
glitches....mechanical and human. But enough of that!!
My 327 is NOT linked to a panel GPS. So now I'm wondering how it knows
you've landed to switch to STBY. A steady pressure altitude could mean
straight and level flight!
--Jeff
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
