Stupid Question from a newbie
Old May 26th 06, 06:45 AM posted to rec.aviation.homebuilt
Default Stupid Question from a newbie
Ok... I'm sure most anyone that reads this will think I'm an idiot, but
I'm so curious...
Could I build an ultralight airframe from EMT (electrical conduit) from
the local hardware store? I know that welding it would be inadvisable
due to the fact that it is galvanized (although I understand that
galvanizing can be 'stripped' thru use of an acid solution) but are
there other differences between standard hardware store emt tubing and
the steel tubing recommended for aircraft construction?
And now for the REALLLY stupid question... what about using PVC tubing?
I know that PVC is much more flexible than steel or aluminum tube, but
could it work? The reason I ask is because I keep thinking that if we
once made airframes out of wood, then wouldn't PVC be just about as
strong and more durable (long lasting?).
Rich
Old May 26th 06, 07:18 AM posted to rec.aviation.homebuilt
I'm so curious...
Nope, and nope.
Both are not suitable for a number of reasons. EMT steel has no quality
tracking. It has poor weight to strength; way too heavy. It also is
brittle after welding. You would have a very heavy airplane, if you
compared it to typical aircraft steel tube.
PVC pipe is also very weak, for the weight. Added to that, the only way to
join them is with fittings, which do not give you many angles to use, and
they are weak, and split. The glue bonds are unreliable. Also, most of the
larger sized PVC pipes are foam core, and that makes them very weak, also.
I think you can't see the forest for the trees. The structure of the
airframe is a small price of a finished aircraft; the wheels, engine,
instruments, hardware, covering, and all the small bits are going to cost
you much more than the structure, perhaps by 3 or 4 times. (just a quick
guess)
Old May 26th 06, 12:14 PM posted to rec.aviation.homebuilt
You can build an airplane out of 1030 mild steel tubing..
You can build an airplane out of wood and fabric...
You can build an airplane out of fiberglass and resin...
You can build an airplane out of plywood...
Go to the EAA site and order a couple of books... Tony BIngelis wrote
a good series... ALex Strojnik also has a great series of books...
REad and understand these two authors and you will be the new Burt
Rutan...
cheers ... denny
Old May 26th 06, 02:26 PM posted to rec.aviation.homebuilt
"Denny" wrote in message oups.com...
Rutan...
cheers ... denny
You can build a plane out of bamboo, plastic sheet, and duct tape...
Old May 26th 06, 03:03 PM posted to rec.aviation.homebuilt
I draw the line at duct tape...
denny
Old May 26th 06, 03:14 PM posted to rec.aviation.homebuilt
denny
I agree, but you gotta start somewhere! http://www.hang-gliding.com/history.html
http://www.geocities.com/Pipeline/Ra...ce/Icesail.htm
http://www.chronogram.com/issue/2005...k/hangtime.php
http://www.octanecreative.com/ductta...ten/index.html
Old May 26th 06, 03:43 PM posted to rec.aviation.homebuilt
In article . com,
I'm so curious...
Not only would you not be the first to try, you would not be the first
to die or injure yourself resulting from said construction.
Old May 26th 06, 05:48 PM posted to rec.aviation.homebuilt
Quote on a T-Shrit I saw---
"I can fix anything"
"Where's the Dict tape"?
Old May 26th 06, 07:48 PM posted to rec.aviation.homebuilt
But it sure sounds fun to dream about it . . .
Old May 26th 06, 08:29 PM posted to rec.aviation.homebuilt
So is dreaming about sleeping with a super model but neither is going to
happen. ;o)
Tony
Landing gear - stupid question... Capt. Geoffrey Thorpe Soaring 9 December 3rd 05 10:31 AM
FS2002 - newbie question Peter Allison Simulators 2 July 15th 04 05:52 PM
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
Newbie FS 2002/04 question Mr Phase Simulators 2 February 11th 04 08:48 AM
Newbie Question Here? FS2004! CRASH Sparky Simulators 3 January 26th 04 02:02 PM
