Rentals in Rochester/NY area?
Old May 26th 06, 11:17 PM posted to rec.aviation.piloting
Default Rentals in Rochester/NY area?
Hi,
a business trip in fall will take me to Rochester/NY and I will
probably have at least two weekends to do some flying.
Any recommendations on where to rent a Skyhawk/Archer-class airplane,
preferrably IFR-equipped, in the area? My research on Airnav did not
bring up too many results, but perhaps there are some locals in this
group who will chime in.
Many thanks...
Tobias
Old May 26th 06, 11:33 PM posted to rec.aviation.piloting
There is a regular in this group from Rochester. Until he chimes in, I
will provide you with what information I have as a resident of a nearby
city.
I called both of the FBOs at the Rochester International Airport (KROC) and
both told me that they do not rent aircraft. However, there are two
separate flight schools on the field that may. I tried to call both and
received answering machines both times, so I couldn't get any more
information. Here are their phone numbers, since someone will most likely
be there over the weekend:
585-328-8839
585-235-5010
If you do get an aircraft, I recommend a scenic flight over the Finger
Lakes, which are about 30 nm due southeast from the ROC (Rochester
International airport), a scenic flight over Letchworth State Park, which
is a river-cut 1,000 foot gorge just 20 nm southwest of ROC, or a scenic
over the Niagara Falls, 45 nm west.
Niagara Falls has an overflight procedure with a minimum altitude
requirement (no flight below 3,500 feet), but the procedure is pretty
simple. There is a discreet frequency to broadcast your position
periodically. If you want more information, I can scan both the overflight
procedure graphic and text and email it to you. Let me know here.
Peter
Old May 27th 06, 01:12 AM posted to rec.aviation.piloting
On Fri, 26 May 2006 17:33:31 -0400, "Peter R."
That's what Airnav says, too. Somewhat strange, isn't it? Admittedly,
my flying experience in the US is limited to CA and AZ, but on
virtually every airport I have visited, there was at least one rental
outfit. And ROC doesn't look that small.
I have found "Big Fella Enterprises" at Ledgedale Airpark (7G0),
which, according to Airnav, rent planes, but their website only
mentions flight training.
Thanks, I will give them a try.
Sounds good. Now the only thing I need is an airplane, but in any case
it's just a matter how far one is willing to drive ;-).
If it's not too much work for you, I'd surely appreciate that.
Thanks for your information...
Tobias
Old May 27th 06, 02:26 AM posted to rec.aviation.piloting
No problem at all. Assuming your email address in your post is valid, I
will have a PDF file with the procedures to you shortly. Let me know here
if you didn't receive them.
Peter
Old May 27th 06, 03:04 AM posted to rec.aviation.piloting
There are two, but they aren't the listed FBOs - the FBOs sell fuel and
services to jets, and Rochester Air Center and Airventure Aviation are
flight schools that rent light planes, sell you charts, all that stuff.
http://www.rochesterair.com/
http://www.airventureaviation.net/
I'll second Peter's recommendations of the Finger Lakes, Letchworth
Canyon, and especially Niagara Falls. Unfortunately I just bought a new
GPS and wiped my old one, so I can't give you the coordinates of the
railway trestle at the south end of Letchworth - it's between a couple of
falls, and it's really the scenic highlight of the park. On your way
there, another cool sight is the wind farm near Perry NY. Just don't
loiter over it, or you'll attract the attention of the TSA.
I don't know if it's still there, but there used to be a pretty decent
aviation museum at Elmira airport (KELM).
"You can get anything you want on Alice's NNTP server."
Old May 27th 06, 04:49 AM posted to rec.aviation.piloting
Yes, it is back in operation after a brush with bankruptcy a couple of
years ago.
http://www.warplane.org/
Matt
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 04:09 AM
Plane Rentals in the Washington D.C. area John T Piloting 4 October 17th 03 05:19 AM
