How to move a T hanger?
Old May 29th 06, 07:11 AM posted to rec.aviation.homebuilt
Default How to move a T hanger?
Anyone have the manual for the breakdown and preparing of a Port A
Port T hanger for transport?
thanks
david
Old May 29th 06, 07:14 AM posted to rec.aviation.homebuilt
"liteflyer 1" wrote in message
Ya might as well ask for the re-assembly guide too.
Old May 30th 06, 06:00 PM posted to rec.aviation.homebuilt
Just do the same things yo did to break it down, only
backwards...
FF
Old May 31st 06, 07:43 AM posted to rec.aviation.homebuilt
The problem is that the left and right "wing" of the hanger are
designed to detach and be moved into the center section. Once they are
in the center section they are secured and the wheels are added, then
you are ready for transport.
The main question is, how do they fit in the center section? Up, down,
left, right, etc.. Do the wheels go in first? Do you take the siding
off to fit them in? Are there special brackets requiered to secure
everything? Where are the lifting points for jacking it up to mount
the wheels?
See my point. I am sure someone has engineering drawings/manuals for
these things.
Thank you
David B
On Mon, 29 May 2006 05:11:29 GMT, liteflyer 1
thanks
david
winch pull of plane into hanger [email protected] Owning 5 April 27th 06 04:55 PM
Heating the hanger Gig 601XL Builder Owning 50 December 20th 05 04:13 PM
Panel urges Navy move some jet training -- perhaps to Kingsville Otis Willie Naval Aviation 1 September 10th 05 04:53 AM
Days as a hanger rat Jack Allison Owning 33 May 12th 05 04:01 AM
Hanger and gliders hit by storm. [email protected] Soaring 6 February 1st 05 02:44 AM
