Monitor FLIP Fixed Here!
Old May 31st 06, 11:28 PM posted to rec.aviation.simulators
Default Monitor FLIP Fixed Here!
jasonjonesiscoolwrote:
The Intel 82915G/GV/910GL chipset has a feature of 'flipping' or
rotating the monitor.
Normally, you would have to click Start Button Settings
Control Panel DOUBLE CLICK Intel(4) GMA Driver Click the
ROTATION tab on top if Enable Rotation is checked, uncheck it
and click APPLY, then OK.
If that does not fix it, you can just choose to rotate it(check the
box and choose by which degree you want it rotated).
Have fun // Jasonbr
I forgot one thing, when it is ENABLED, you can switch between each
angle(0, 90, 180, 270) by pressing (CTRL+ALT+UP) at the same
time.... or choose down, left, or right....
Old July 16th 06, 04:33 PM posted to rec.aviation.simulators
CriticalMass
jasonjonesiscool = serious egocentrism
Blair was told US 'fixed' case for war [email protected] Naval Aviation 0 March 21st 05 10:05 PM
Trike vs Fixed Wing U/L vs Gyros BARTFIO Home Built 0 September 2nd 04 07:13 PM
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Naval Aviation 5 August 21st 04 12:50 AM
Fixed vs All Flying tail Kevin Neave Soaring 1 March 13th 04 05:02 AM
book fixed wing a/c losses vietnam old hoodoo Military Aviation 4 October 19th 03 08:54 PM
