Help with S-TEC 50 A/P
Old June 3rd 06, 12:33 AM posted to rec.aviation.piloting
Default Help with S-TEC 50 A/P
Okay, one of the club's planes has an autopilot installled, that I have
never been able to make operate. Get up to level cruise, turn it on and
wait. All I get is a blinking 'TRIM UP' light, never get the 'READY' light.
Is it hosed, or am I missing a step?
Hello, my name is Mike, and I am an airplane addict...
Old June 3rd 06, 01:12 AM posted to rec.aviation.piloting
light.
Switch it to "Test" first. It will do its test sequence, ending with a
bunch of lights on, including the "Trim Up" light, IIRC.
Then, switch it to "On." The green "Rdy" light will illuminate. If you now
press the "On" button, the "Push Hdg/Sts"activates in wing leveler mode.
Press the "Push Hdg/Sts" button and the autopilot will steer to the course
set on the heading bug. Once the bank axis is active, the altitude hold
function is available.
Dan
C172RG at BFM
Old June 3rd 06, 01:31 AM posted to rec.aviation.piloting
light.
There is a delay of one or two minutes before the altitude hold will
engage. Be patient.
Old June 3rd 06, 01:37 AM posted to rec.aviation.piloting
"john smith" wrote in message
have
and
light.
now
course
engage. Be patient.
OK thanks guys. Had it out visiting relatives last weekend. Not much fun
openening/folding sectionals with one hand.
Old June 7th 06, 09:11 PM posted to rec.aviation.piloting
engage. Be patient.
And in my experience, you don't want to be trying to get the altitude
hold to engage as soon as it possibly will. There seems to be a small
window where it will engage but immediately command a slight nose up/down
rather than just holding altitude. Passengers don't like it!
Ben Jackson
http://www.ben.com/
Old June 3rd 06, 01:34 AM posted to rec.aviation.piloting
"Dan Luke" wrote in message
light.
now
Dan
C172RG at BFM
Thanks, Dan. I love the 296, BTW. Very useful.
Old June 3rd 06, 06:35 AM posted to rec.aviation.piloting
On Fri, 2 Jun 2006 19:12:29 -0500, "Dan Luke"
light.
Mine must be broke. I can turn on alt hold with out the heading being
active. It doesn't care which sequence I use other than it takes a
minute or so before the altitude hold works after turning the AP on.
www.rogerhalstead.com
Old June 3rd 06, 02:46 PM posted to rec.aviation.piloting
When you press the "On/Off" button, the roll axis is active (you can control
the turn rate by twisting the knob). The altitude hold function is then
available.
Dan
C172RG at BFM
Old June 6th 06, 04:45 PM posted to rec.aviation.piloting
Roger,
active.
That's by design. If HDG mode is off, but you have the autopilot
switched on, STB will be showing in the display, which stands for
STABILIZE, otherwise known as wing leveling. Of course, you can hold
ALT in that mode.
Thomas Borchert (EDDH)
Old June 3rd 06, 02:27 AM posted to rec.aviation.piloting
On Fri, 02 Jun 2006 23:33:40 GMT, "Michael Ware"
The a/c should have an AFM supplement explaining how to test the a/p during
PREFLIGHT. If you cannot locate it, you can always download the POH from
http://www.s-tec.com/pdf/sys4050poh.PDF
Once you have read the manual, and gone through the pre-flight test
procedure, you should be able to figure out whether the problem lies in the
autopilot, or the operator.
Under normal circumstances, the 'READY' light should have been on prior to
takeoff.
