I have a fairly new Instrument Rating and need to fly my (non-turbo) Arrow
from Chicago to Binghamton NY. The most efficient dry route appears to be V6 via Dryer, but that takes me right through the middle of the Cleveland Class B. Is this likely to be accepted as filed, or am I likely to get vectored extensively out of the way? I need to know for fuel planning (old Arrow, small tanks). The Canada route is a little longer and that runs through Detroit Class B. Suggestions/experiences from any of you graybeards (figuratively, of course) out there would be appreciated. |
I've traveled from White Plains NY to Burke Lakefront monthly for the past
year. Most times they offer Class B clearance before asking. They may give you an altitude change but will probably clear you through. It's usually not until you're east of the Poconos (around Wilkes-Barre) that they start giving you extensive routing. Steve S "dutch" wrote in message link.net... I have a fairly new Instrument Rating and need to fly my (non-turbo) Arrow from Chicago to Binghamton NY. The most efficient dry route appears to be V6 via Dryer, but that takes me right through the middle of the Cleveland Class B. Is this likely to be accepted as filed, or am I likely to get vectored extensively out of the way? I need to know for fuel planning (old Arrow, small tanks). The Canada route is a little longer and that runs through Detroit Class B. Suggestions/experiences from any of you graybeards (figuratively, of course) out there would be appreciated. |
Cleveland is quite accomondating for GA aircraft compared to other CBAS
(like PHX). "dutch" wrote in link.net: I have a fairly new Instrument Rating and need to fly my (non-turbo) Arrow from Chicago to Binghamton NY. The most efficient dry route appears to be V6 via Dryer, but that takes me right through the middle of the Cleveland Class B. Is this likely to be accepted as filed, or am I likely to get vectored extensively out of the way? I need to know for fuel planning (old Arrow, small tanks). The Canada route is a little longer and that runs through Detroit Class B. Suggestions/experiences from any of you graybeards (figuratively, of course) out there would be appreciated. |
"dutch" wrote in message hlink.net...
Is this likely to be accepted as filed, or am I likely to get vectored extensively out of the way? Probably not very far out of the way. Hopkins traffic tends to use a fairly tight "box" pattern. Be ready to steer around the downwind and base legs and you're golden. The Canada route is a little longer and that runs through Detroit Class B. Flying over Niagra Falls on the way can be fun. Buffalo's very cool about that. Detroit's "arrival corridors" seem to be much bigger than Cleveland's, but in a way they're easier to steer through. Detroit seems to like keeping the scheduled and GA traffic far away from each other, and is very GA-friendly in doing it. |
I have flown from Milwaukee to east of CLE a number of times. Most of the
routings took me over or around the Detroit airspace and over Lake Erie. This was not a big deal flying in a twin, but made me pretty nervous the one time I did it in a single. |
CLE is very smooth compared to DTW. If traffic is from SW to RWY 5, you
may get sent to MFD and then via the MFD 092 radial eastward. dutch wrote: I have a fairly new Instrument Rating and need to fly my (non-turbo) Arrow from Chicago to Binghamton NY. The most efficient dry route appears to be V6 via Dryer, but that takes me right through the middle of the Cleveland Class B. Is this likely to be accepted as filed, or am I likely to get vectored extensively out of the way? I need to know for fuel planning (old Arrow, small tanks). The Canada route is a little longer and that runs through Detroit Class B. Suggestions/experiences from any of you graybeards (figuratively, of course) out there would be appreciated. |
I don't know CLE airspace that well, but I have flown through NY's class
B IFR a few times without trouble in the past 6 months or so. (Not a whole lot of experience, admittedly, but I've done it several times now). Basically, they had my fly the preferred route at the defined altitude with little or no additional vectoring except to give me a chance to get to my altitude (6000' that day). It might be overkill, because they'll change your routing if they need to anyway, but I would check the AFD for prefferred routes from airports near your intended flight path, and file on their routes at their altitudes. I would suspect that you have the least amount of likelihood of being vectored around if you are in their "highway" system following along with everyone else... It may be slightly less direct for you, but I would guess it is more likely to be accepted as filed that way. I would suggest you bring your flight computer and some scrap paper. If you're that close on fuel, you should probably create a "backup plan" stop in case the winds are going to put you over anyway... I haven't looked at your flight plan, but I fly an archer, and my max fuel time is about 90 minutes longer than my max bladder time, so I never really have that problem anyway. ![]() "dutch" wrote in link.net: I have a fairly new Instrument Rating and need to fly my (non-turbo) Arrow from Chicago to Binghamton NY. The most efficient dry route appears to be V6 via Dryer, but that takes me right through the middle of the Cleveland Class B. Is this likely to be accepted as filed, or am I likely to get vectored extensively out of the way? I need to know for fuel planning (old Arrow, small tanks). The Canada route is a little longer and that runs through Detroit Class B. Suggestions/experiences from any of you graybeards (figuratively, of course) out there would be appreciated. |
| Thread Tools | |
| Display Modes | |
| Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 03:29 AM |
| airspace G | Jim Anglin | Home Built | 8 | February 23rd 04 12:29 AM |
| vfr corridors through class B airspace | [email protected] | Instrument Flight Rules | 26 | November 3rd 03 12:28 AM |
| IA to Class E | Sydney Hoeltzli | Instrument Flight Rules | 6 | July 14th 03 03:29 PM |
